Setting up Development Toolchain for ESP32
1. I have downloaded the esp32_win32_msys2_environment_and_toolchain-20170330,
2. then made git clone --recursive https://github.com/espressif/esp-idf.git in under a directory C:\ESP\esp-idf
3. Downloaded the template into directory myapp2 git clone https://github.com/espressif/esp-idf-template.git myapp2
4. Exported export IDF_PATH="C:\ESP\esp-idf"
5. Then hit the make command to compile the project. make
then errors occurs:
$ make
/bin/sh: python: not fund command
make[1]: *** [/c/ESP/esp-idf/components/esptool_py/Makefile.projbuild:49: /c/esp/myapp2/build/bootloader/bootloader.bin] ERROR 127
make: *** [/c/ESP/esp-idf/components/bootloader/Makefile.projbuild:31: /c/esp/myapp2/build/bootloader/bootloader.bin] ERROR 2
Please for any advice.
Many thanks,
Pawel
then errors occurs:
$ make
Many thanks,
Pawel
Re: Setting up Development Toolchain for ESP32
Hi
make sure to run "minigw32.exe" (or 64) and not "msys2.exe"
I`m running msys2_shell.cmd
Regards,
Pawel
Regards,
Pawel
No, you must run minigw32.exe as explained in the guide:
http://esp-idf.readthedocs.io/en/latest ... setup.html
Check it Out
Open an MSYS2 terminal window by running C:\msys32\mingw32.exe. The environment in this window is a bash shell.
Check it Out
I have made everything following by tutorial.
As soon as I make this step: http://esp-idf.readthedocs.io/en/latest ... et-esp-idf nothing works..
Before I`ve downloaded
command menuconfig was working
pbl@pbl-Komputer MINGW64 ~
$ make menuconfig
make: *** No rules to execute object 'menuconfig'. Stop.
$ make flash
make: *** No rules to execute object 'flash'. Stop.
You should change directory to place where you have example project or template before executing "make"
But according to your output your current dir is your home dir (~)
pbl@pbl-Komputer MINGW64 /c/ESP/esp-idf/examples/get-started
$ make flash
Dir where you run 'make' should have 'Makefile', for example "esp-idf/examples/get-started/hello_world"
There it is.
I don`t know...maybe I should start installation at the beginning? Remove all and then start again?
- ESP_krzychb
- Contact:
Yes, this is advisable to start from scratch but following step by step http://esp-idf.readthedocs.io/en/latest ... index.html.I don`t know...maybe I should start installation at the beginning? Remove all and then start again?
If you diverge from this procedure it takes extra time and effort to find out the issue and help you out.
Users browsing this forum: Google [Bot] and 85 guests
