Issue with two SPI devices on same bus
apuder
Postby apuder » Sat Dec 11, 2021 12:44 am
Hi all. I have two SPI devices connected to an ESP32; a micro-SD card and an FGPA. Both work fine, however, because of some timing issues I can clock the SPI signal to the FPGA only at 5 MHz. I want to use the dummy bit workaround as described in the documentation, however, this let me down a rabbit hole. I changed the SPI transaction to the FPGA to SPI_DEVICE_HALFDUPLEX and "abused" the command and address bits for sending data (which is also suggested in the documentation). That code works and I can talk to the FPGA (still at 5 MHz for now; I haven't done the dummy bit yet). Unfortunately, that change has some impact on the communication with the SD card. Once I have made one SPI transaction with the FPGA, I am getting the following errors when trying to access the SD card:
E (26231) sdmmc_cmd: sdmmc_read_sectors_dma: sdmmc_send_cmd returned 0x107
E (26239) diskio_sdmmc: sdmmc_read_blocks failed (263)
Some more details on my implementation: I am using ESP-IDF 4.2.2. I use HSPI_HOST for both SPI devices. Here is how I initialize the HSPI_HOST:
  spi_bus = {
        .mosi_io_num = SPI_PIN_NUM_MOSI,
        .miso_io_num = SPI_PIN_NUM_MISO,
        .sclk_io_num = SPI_PIN_NUM_CLK,
        .quadwp_io_num = -1,
        .quadhd_io_num = -1,
        .max_transfer_sz = 4000,
  esp_err_t ret = spi_bus_initialize(HSPI_HOST, &spi_bus, 1);
Here is how I add the FPGA as a SPI device:
  // Configure SPI device for the Cmod A7
  spi_cmod.address_bits = 0;
  spi_cmod.command_bits = 1 * 8;
  spi_cmod.dummy_bits = 0;
  spi_cmod.mode = 0;
  spi_cmod.duty_cycle_pos = 0;
  spi_cmod.cs_ena_posttrans = 0;
  spi_cmod.cs_ena_pretrans = 0;
  spi_cmod.clock_speed_hz = SPI_SPEED_MHZ * 1000 * 1000;
  spi_cmod.spics_io_num = SPI_PIN_NUM_CS_CMOD;
  spi_cmod.flags = SPI_DEVICE_HALFDUPLEX;
  spi_cmod.queue_size = 1;
  spi_cmod.pre_cb = NULL;
  spi_cmod.post_cb = NULL;
  ret = spi_bus_add_device(HSPI_HOST, &spi_cmod, &spi_cmod_h);
And finally here is how I add the SD card as a SPI device:
  sdmmc_host_t host = SDSPI_HOST_DEFAULT();
  host.max_freq_khz = SDMMC_FREQ_PROBING;
  sdspi_device_config_t slot_config = SDSPI_DEVICE_CONFIG_DEFAULT();
  slot_config.gpio_cs = SPI_CS;
  slot_config.host_id = HSPI_HOST;
  esp_err_t ret = VFS::esp_vfs_fat_sdspi_mount(mount, &host, &slot_config, &mount_config, &card);
Here are the GPIO pins used: MISO (22), MOSI (21), SCK (25), CS_FPGA (26), CS_SD (23).
Well, I'm at the end of my wits. Hopefully someone can point me in the right direction. I've attached the log as well.
TIA,
AP
log.txt
(26.51 KiB) Downloaded 375 times
apuder
Re: Issue with two SPI devices on same bus
Postby apuder » Thu Dec 16, 2021 9:38 pm
So, after some more digging it appears that my problem is the same as the one described here: https://www.esp32.com/viewtopic.php?t=13719
What I wasn't explicit about in my original post: everything worked fine when I used full-duplex connections to both SPI devices. Things started to break once I switched one SPI device to half-duplex. After sending a transaction to the half-duplex device, it seems to mess up the SPI configuration to the SD card. At this point I'm inclined to believe that this might be a bug in ESP-IDF.
AP
Users browsing this forum: Bing [Bot], ESPBoards, Google [Bot] and 166 guests
