touch_pad_config vs touch_pad_set_thresh? No difference?
mezzynine
Postby mezzynine » Sun Sep 26, 2021 1:53 pm
Hi, what's the difference between touch_pad_config() and touch_pad_set_thresh()? They take the same parameters:
esp_err_t touch_pad_config(touch_pad_t touch_num, uint16_t threshold)
esp_err_t touch_pad_set_thresh(touch_pad_t touch_num, uint16_t threshold)
mezzynine
Re: touch_pad_config vs touch_pad_set_thresh? No difference?
Postby mezzynine » Sun Sep 26, 2021 2:09 pm
The answer, from o-marshmallow
(https://github.com/o-marshmallow) on the ESP32 IDF github:
About touch_pad_thresh, its goal is to modify the threshold at runtime, whereas touch_pad_config is used for initialization. It does more than setting the threshold.
https://github.com/espressif/esp-idf/is ... -927284245
Users browsing this forum: Google [Bot] and 104 guests
