Flashing firmware from Linux under Windows (WSL)
Fredckx
Postby Fredckx » Fri Sep 03, 2021 10:31 am
Hi, I installed ESP-IDF under Linux (Ubuntu 20.04 LTS under WSL 2 , this is Linux under Windows). I did this because I need to run some Linux scripts to generate ny source code. Calling "idf.py build" runs OK, but flashing fails because COM ports are not supported. Anyone with experience on Linux/WSL/flashing? or Linux/WSL/COM ports?
ns1668
Re: Flashing firmware from Linux under Windows (WSL)
Postby ns1668 » Fri Sep 03, 2021 11:06 am
Are you connecting to a devkit board via USB? WSL2 does not currently support serial or USB devices.
My suggestion would be to migrate you environment to a proper linux virtual machine (virtualbox or something similar).
Users browsing this forum: Twist3r and 142 guests
