ESP32 with Lepton
ZePedro80
ESP32 with Lepton
Postby ZePedro80 » Thu Jul 29, 2021 4:08 pm
Hello everyone!
In my project I am using a Lepton FLIR 3.5 coupled in a Lepton FLIR Breakout Board v2.0 connected to a Adafruit ESP32 Feather, but following this tutorial: https://lepton.flir.com/getting-started ... pi-lepton/
However, the only connection that I didn’t use was the VSYNC, because I don’t know which pin in the ESP32 should I connect to it.
Thus, when I print the sensor matrix in the Serial Monitor, the first lines are wrong (0 or 65528, most of the time), but the remaining seem ok (attached image). It seems a syncronization problem, i.e., the sensor is not grabing the first values, but when it grabs the image it saves the remaining values.
Do you think that’s because I didn’t use the VSYNC pin? If so, where should I connect it in my ESP32?
IR sensor Matrix.png (206.28 KiB) Viewed 3645 times
ZePedro80
Re: ESP32 with Lepton
Postby ZePedro80 » Fri Jul 30, 2021 9:21 am
I now can print a full matrix of values, but this matrix is everytime the same one (the values don't change).
However, when I upload the code in Arduino IDE, the matrix changes compared to that of the previous compiling.
Any idea of what it might be?
MKitchlew
Postby MKitchlew » Tue Mar 15, 2022 6:17 pm
Hi ZePedro
I'm running into some issues with my own FLIR Lepton 3.5 and ESP 32. Can we connect on call and discuss this? (tried inboxing you but I don't have access)
Users browsing this forum: No registered users and 66 guests
