GPIO max input/output current
Wicked
Postby Wicked » Wed Jun 16, 2021 8:28 am
Hi !
I have an ESP32 WROOM 32 and I'm a bit confused on what is the maximum current a GPIO can output or take in ?
I've read different articles that say either 12mA or 40mA . The datasheet doesnt help much either.
PS: I'm using a relay that needs 15 mA to activate so that's why im wondering. I also have an ultrasonic sensor that works at 5V and outputs a signal, but I made sure to use voltage divider to lower the voltage input on the pin
Thanks !
Re: GPIO max input/output current
Postby ESP_Sprite » Thu Jun 17, 2021 2:05 am
You can source 40mA from these pins at max, but you may need to tweak the drive pins to obtain this. (The 12mA number is for the 8266, but that was in the datasheet for the ESP32 for a while as well as it took us some time to obtain the final figures for this.)
Wicked
Postby Wicked » Thu Jun 17, 2021 6:27 am
Thank you for the fast reply ! Im trying to write a small introduction for this board, like 2-3 pages , and all this information is really needed. Thanks again
vanBassum
Postby vanBassum » Wed Jun 23, 2021 6:34 am
Don't forget to add a diode over the coil to catch the induced voltage when the relais is switched off!
BTW, I would always use something like a transistor in cases like this. The output meight be able to drive the coil, you don't really want to do this. Especially in a long term solution.
https://aws1.discourse-cdn.com/arduino/ ... d57eb.jpeg
Postby ESP_Sprite » Thu Jun 24, 2021 1:17 am
This is true, especially since the relay is an inductive load, it may initially pull a lot more than 40mA. Better use a transistor.
Users browsing this forum: No registered users and 70 guests
