ESP32 - GPIO speed lower than expected
Alizame
Postby Alizame » Tue Apr 04, 2017 3:16 pm
Hi guys :)
I recently got my ESP32 (it's Rev0, I already checked that) and it runs fine, except that I don't get why the maximum toggle frequency for GPIOs seems to be 4 MHz.
w1ts w1tc 4mhz.png (34.2 KiB) Viewed 109882 times
Is this really the maximum (the peripheral bus clock rate is 80MHz, so shouldn't it be 40MHz?)? Or are now the slow register-adresses (as mentioned in the ECO pdf) standard?
Im running the latest IDF (from github) and my project is based on the esp-idf-template (again form github).
My Toggle-function runs on Core1 (as a thread pinned to it).
I use GPIO.out_w1ts and GPIO.w1tc to set/clear the GPIO.
I have tried to simplify the code code as far as possible eliminate any "codelogic-errors".
The critical code section:
void toggle(void *pvParameter) {
	printf("toggle called.\n");
	portDISABLE_INTERRUPTS();
	while (1) {
		GPIO.out_w1ts |= (1 << GPIO_NUM_23);
		__asm__ __volatile__("nop;nop;nop;nop;nop;nop;nop;"); // Bug workaround (I found this snippet somewhere in this forum)
		GPIO.out_w1tc |= (1 << GPIO_NUM_23);
	// GPIO.out doesn't make any difference
	portENABLE_INTERRUPTS();
My complete main.c file: https://pastebin.com/9eYRUMVs , maybe you can check for errors :)
So why do I want to Toggle a GPIO as fast as possible? Why not...
I'm trying to get data as fast as possible into 4 x 8 D-FlipFlops (4 x 74ahct574), so I have 8 data lines and 4 clock lines.
Im new to ESP32 so I don't exactly know yet, how some of the peripherals/DMA work, so I thought this would be a good start
I am thankful for any help and maybe you can point me in the right direction to solve my problem.
PS: I'm sorry for any spelling/grammar errors, I'm not a native speaker.
Hans Dorn
Re: ESP32 - GPIO speed lower than expected
Postby Hans Dorn » Wed Apr 05, 2017 1:25 am
Hi Alizame,
as far as I understand the w1ts/w1tc registers, you don't have to read them out to set/reset GPIO bits.
Try this version:
   while (1) {
      GPIO.out_w1ts = (1 << GPIO_NUM_23);
      GPIO.out_w1tc = (1 << GPIO_NUM_23);
rsimpsonbusa
Postby rsimpsonbusa » Wed Apr 05, 2017 1:43 am
Tried it with a logical analyzer same result. Very slow. STM32f4 is 100MHZ.
Screen Shot 2017-04-04 at 8.41.38 PM.png (49.78 KiB) Viewed 109879 times
ESP_Angus
Postby ESP_Angus » Wed Apr 05, 2017 4:31 am
For pin twiddling, you can get to 10MHz if you remove the "bug workaround":
while (1) {
    GPIO.out_w1ts = (1 << TogglePin);
    GPIO.out_w1tc = (1 << TogglePin);
(No workaround is necessary here, the R0 silicon bug only triggers if you write to the same register multiple times in a row, but this code is writing two registers - OUT_W1TS & OUT_W1TC - alternately.)
A quick peek at the generated assembly shows that's pretty close to optimal:
xtensa-esp32-elf-objdump -S build/app-template.elf
        while (1) {
400f1d10:       7a0d81          l32r    a8, 400d0544 <_flash_cache_start+0x52c>
400f1d13:       7a0d91          l32r    a9, 400d0548 <_flash_cache_start+0x530>
400f1d16:       0020c0          memw
400f1d19:       2899            s32i.n  a9, a8, 8
400f1d1b:       0020c0          memw
400f1d1e:       3899            s32i.n  a9, a8, 12
400f1d20:       fffb06          j       400f1d10 <app_main+0x1c>
If you compile in Release mode then the extra compiler optimisation moves the jump target so it doesn't reload a8 & a9 each time around the loop, which doesn't actually change the result (due to CPU pipeline, buffered writes, slower I/O bus).
If you rewrite in inline assembler then you can even take out the memory barrier "memw" instructions for absolute minimum code size, but this also doesn't change the result - the CPU waits for the previous write to each register to complete before it writes there again.
We realise that 10MHz is not terribly fast, however using a fast CPU to bit-bang values is also much more fiddly than bit-banging on a simple 8-bit microcontroller. ESP32 has peripherals which help with this:
  • The RMT Peripheral is nominally designed to send/receive IR remote control signals, but can send/receive arbitrary pulse sequences. For example here is a project that uses it to drive addressable LED strings.
  • The SPI buses all function in DMA mode when using the IDF included driver, so you can clock data in/out at up to 80MHz.
  • The I2S peripheral can be used in a parallel mode to drive a single clock and multiple data inputs/output pins, also via DMA. I don't think a general-purpose driver is available for this yet. Ivan's camera example shows how to do it for clocking parallel data in, I'm not sure if a similar example exists for parallel data output yet.
If you can offload the bit-twiddling work to the peripherals, then CPU can spend its time handling WiFi, Bluetooth, high-level logic, etc.
Alizame
Postby Alizame » Wed Apr 05, 2017 2:04 pm
A new problem arrived :D
code: https://pastebin.com/7ZC6Y4yU
If I write to GPIO.out_w1ts directly (like "GPIO.out_w1ts = (1 << 23);" ), my Core0 crashes or something like that (TG1WDT_SYS_RESET happens and Core0 doesn't print that it got to my loop function, but the GPIO gets set correctly until the ESP resets).
If I write it like "GPIO.out_w1ts |= (1 << 23), everything works fine (but slower). Also GPIO.out_w1tc works perfectly as expected.
Serial Output:
ets Jun 8 2016 00:22:57
configsip: 0, SPIWP:0x00
mode:DIO, clock div:1
load:0x3fff0008,len:8
load:0x3fff0010,len:3384
load:0x40078000,len:7428
load:0x40080000,len:252
entry 0x40080034
I (43) boot: ESP-IDF v2.0-rc1-387-g47b8f78 2nd stage bootloader
I (43) boot: compile time 15:13:16
I (44) boot: Enabling RNG early entropy source...
I (64) boot: SPI Speed : 80MHz
I (76) boot: SPI Mode : DIO
I (89) boot: SPI Flash Size : 4MB
I (101) boot: Partition Table:
I (112) boot: ## Label Usage Type ST Offset Length
I (135) boot: 0 nvs WiFi data 01 02 00009000 00006000
I (158) boot: 1 phy_init RF data 01 01 0000f000 00001000
I (182) boot: 2 factory factory app 00 00 00010000 00100000
I (205) boot: End of partition table
I (218) boot: Disabling RNG early entropy source...
I (235) boot: Loading app partition at offset 00010000
I (787) boot: segment 0: paddr=0x00010018 vaddr=0x00000000 size=0x0ffe8 ( 65512)
I (788) boot: segment 1: paddr=0x00020008 vaddr=0x3f400010 size=0x07004 ( 28676) map
I (804) boot: segment 2: paddr=0x00027014 vaddr=0x3ffb0000 size=0x023ac ( 9132) load
I (832) boot: segment 3: paddr=0x000293c8 vaddr=0x40080000 size=0x00400 ( 1024) load
I (857) boot: segment 4: paddr=0x000297d0 vaddr=0x40080400 size=0x1994c (104780) load
I (913) boot: segment 5: paddr=0x00043124 vaddr=0x400c0000 size=0x00000 ( 0) load
I (914) boot: segment 6: paddr=0x0004312c vaddr=0x00000000 size=0x0cedc ( 52956)
I (934) boot: segment 7: paddr=0x00050010 vaddr=0x400d0018 size=0x377ac (227244) map
I (960) cpu_start: Pro cpu up.
I (971) cpu_start: Starting app cpu, entry point is 0x40080b08
I (0) cpu_start: App cpu up.
I (1003) heap_alloc_caps: Initializing. RAM available for dynamic allocation:
I (1026) heap_alloc_caps: At 3FFAE2A0 len 00001D60 (7 KiB): DRAM
I (1046) heap_alloc_caps: At 3FFB7448 len 00028BB8 (162 KiB): DRAM
I (1068) heap_alloc_caps: At 3FFE0440 len 00003BC0 (14 KiB): D/IRAM
I (1089) heap_alloc_caps: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM
I (1111) heap_alloc_caps: At 40099D4C len 000062B4 (24 KiB): IRAM
I (1131) cpu_start: Pro cpu start user code
I (1188) cpu_start: Starting scheduler on PRO CPU.
I (202) cpu_start: Starting scheduler on APP CPU.
I (202) wifi: wifi firmware version: 1f2a9e1
I (202) wifi: config NVS flash: enabled
I (202) wifi: config nano formating: disabled
I (202) wifi: Init dynamic tx buffer num: 32
I (202) wifi: wifi driver task: 3ffbd1d4, prio:23, stack:3584
I (202) wifi: Init static rx buffer num: 10
I (202) wifi: Init dynamic rx buffer num: 0
I (212) wifi: Init rx ampdu len mblock:7
I (212) wifi: Init lldesc rx ampdu entry mblock:4
I (212) wifi: wifi power manager task: 0x3ffc257c prio: 21 stack: 2560
I (222) wifi: wifi timer task: 3ffc35fc, prio:22, stack:3584
I (252) phy: phy_version: 350, Mar 22 2017, 15:02:06, 0, 0
I (252) wifi: mode : sta (24:0a:c4:07:8a:84)
toggle called.
rst:0x8 (TG1WDT_SYS_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
entry 0x40080034
I (264) boot: ESP-IDF v2.0-rc1-387-g47b8f78 2nd stage bootloader
I (264) boot: compile time 15:13:16
I (264) boot: Enabling RNG early entropy source...
I (285) boot: SPI Speed : 80MHz
I (298) boot: SPI Mode : DIO
I (311) boot: SPI Flash Size : 4MB
I (323) boot: Partition Table:
I (335) boot: ## Label Usage Type ST Offset Length
I (357) boot: 0 nvs WiFi data 01 02 00009000 00006000
I (381) boot: 1 phy_init RF data 01 01 0000f000 00001000
I (404) boot: 2 factory factory app 00 00 00010000 00100000
I (427) boot: End of partition table
I (440) boot: Disabling RNG early entropy source...
I (457) boot: Loading app partition at offset 00010000
I (1009) boot: segment 0: paddr=0x00010018 vaddr=0x00000000 size=0x0ffe8 ( 65512)
I (1010) boot: segment 1: paddr=0x00020008 vaddr=0x3f400010 size=0x07004 ( 28676) map
I (1026) boot: segment 2: paddr=0x00027014 vaddr=0x3ffb0000 size=0x023ac ( 9132) load
I (1055) boot: segment 3: paddr=0x000293c8 vaddr=0x40080000 size=0x00400 ( 1024) load
I (1080) boot: segment 4: paddr=0x000297d0 vaddr=0x40080400 size=0x1994c (104780) load
I (1137) boot: segment 5: paddr=0x00043124 vaddr=0x400c0000 size=0x00000 ( 0) load
I (1138) boot: segment 6: paddr=0x0004312c vaddr=0x00000000 size=0x0cedc ( 52956)
I (1158) boot: segment 7: paddr=0x00050010 vaddr=0x400d0018 size=0x377ac (227244) map
I (1184) cpu_start: Pro cpu up.
I (1195) cpu_start: Starting app cpu, entry point is 0x40080b08
I (1228) heap_alloc_caps: Initializing. RAM available for dynamic allocation:
I (1251) heap_alloc_caps: At 3FFAE2A0 len 00001D60 (7 KiB): DRAM
I (1271) heap_alloc_caps: At 3FFB7448 len 00028BB8 (162 KiB): DRAM
I (1292) heap_alloc_caps: At 3FFE0440 len 00003BC0 (14 KiB): D/IRAM
I (1314) heap_alloc_caps: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM
I (1335) heap_alloc_caps: At 40099D4C len 000062B4 (24 KiB): IRAM
I (1356) cpu_start: Pro cpu start user code
I (1413) cpu_start: Starting scheduler on PRO CPU.
toggle called.
As you can see the "loop called" from the loop function never gets printed out and the Watchdog starves ;(
I hope you can help me again ;)
ESP_Angus
Postby ESP_Angus » Thu Apr 06, 2017 12:16 am
I think this is probably something to do with the fact that the task is permanently disabling interrupts. When I was playing with that code it also regularly reset itself.
If you disable interrupts in chunks, and come up for a breather now and then (just re-enabling them and immediately disabling them should be enough) then it should be OK.
Alizame
Postby Alizame » Thu Apr 06, 2017 11:00 am
Ok, I can confirm that it has something todo with the disabling of the interrupts.
But is there any explanation why it only happens if I try to write to w1ts directly (and not with or) and everything works fine for w1tc?
Btw: is there any ETA on when I2S-Parallel Driver/Documentation will be available?
Pallav Aggarwal
Postby Pallav Aggarwal » Wed Mar 18, 2020 5:38 pm
I was able to get 10Mhz @ESP32 working at 240Mhz with following instructions:
You can save on bit shifting the bit 1<<(2)
GPIO.out_w1ts = 0x04; // GPIO2 HIGH
GPIO.out_w1tc = 0x04; // GPIO2 LOW
My code was compiled still in debug mode.
Not sure, if there is a way to increase the speed a bit more?
Best Regards
Pallav Aggarwal
https://pallavaggarwal.in/
mad_b747
Postby mad_b747 » Sun Apr 12, 2020 1:30 pm
Not sure for the expressif toolchain, but since many years ago, when one puts an instruction in the code that is a fixed math or logical expression, usually the compiler converts it to the resulting value, so should be no difference in writing 1<<3 or writing 8 or 0x8 or 0x08.
PeterR
Postby PeterR » Tue Jun 23, 2020 11:44 pm
I am not tuning in to why you want to bit bang. In your other posts you go on to propose a parallel port.
The problem with these appoaches are asynchronous/aliasing behaviour.
Why not use the peripherals which ESP provide?
One might imagine that ESP drivers address the various silicon issues better than a GPIO driven at speed.
What is wrong with RMT, SPI, I2S etc?
PS
STM 100Mhz; look at the various buses and clocks. Some buses have multiple uses and your CPU clock may not be that bus' frequency (& often is not an x2 of you're CPU). CubeMx has a good diagram. Plus other stuff may use the bus of interest. Think how software cycles may then interact & I would say; use the manufacturer's peripheral logic & get out to the bar quicker. A point of view but ....
Users browsing this forum: No registered users and 72 guests
