Esp32 keep rebooting problem
a24356789
Postby a24356789 » Sun Dec 06, 2020 4:38 pm
Hi?
When i upload the bluetooth program to it,I don't know why my esp 32 keep rebooting.
Rebooting...
ets Jun 8 2016 00:22:57
configsip: 0, SPIWP:0xee
mode:DIO, clock div:2
load:0x3fff0018,len:4
load:0x3fff001c,len:928
ho 0 tail 12 room 4
load:0x40078000,len:10080
load:0x40080400,len:5828
entry 0x400806a8
Guru Meditation Error: Core 0 panic'ed (LoadStoreError). Exception was unhandled.
Core 0 register dump:
PC : 0x40114b9d PS : 0x00060b30 A0 : 0x800defb8 A1 : 0x3ffcff20
A2 : 0x400df00c A3 : 0x3ffbdc68 A4 : 0x3f407018 A5 : 0x00001400
A6 : 0x00001800 A7 : 0x00000003 A8 : 0x80114b9d A9 : 0x3ffcfed0
A10 : 0x3ffdf474 A11 : 0x00000000 A12 : 0x00000000 A13 : 0x00001800
A14 : 0x00000000 A15 : 0x3ffcde80 SAR : 0x00000010 EXCCAUSE: 0x00000003
EXCVADDR: 0x3f40701c LBEG : 0x4000c46c LEND : 0x4000c477 LCOUNT : 0x00000000
ELF file SHA256: 0000000000000000
Backtrace: 0x40114b9d:0x3ffcff20 0x400defb5:0x3ffcff40 0x400df606:0x3ffcff90 0x400d597d:0x3ffcffb0 0x4008f53a:0x3ffcffe0
Rebooting...
ho 0 tail 12 room 4
entry 0x400806a8
A14 : 0x00000000 A15 : 0x3ffcde80 SAR : 0x00000000 EXCCAUSE: 0x00000003
what problem?
Re: Esp32 keep rebooting problem
Postby ESP_Sprite » Mon Dec 07, 2020 1:42 am
No clue, the info you provide is way too little. Step 1 would be to decode the backtrace. Use addr2line or use the esp.py monitor function for that.
a24356789
Postby a24356789 » Mon Dec 07, 2020 2:46 am
Flash Frequency: 40MHz
Flash mod: Dio
Flash size: 4MB
PSRAM: Disabled
This is the code:
#include "BluetoothSerial.h"
#if !defined(CONFIG_BT_ENABLED) || !defined(CONFIG_BLUEDROID_ENABLED)
#error Bluetooth is not enabled! Please run `make menuconfig` to and enable it
#endif
BluetoothSerial SerialBT;
void setup() {
Serial.begin(115200);
SerialBT.begin("ESP32P01");
pinMode(25, OUTPUT);
digitalWrite(25, HIGH); // LED Red
delay(500);
digitalWrite(25, LOW); // LED Red
delay(500);
delay(500);
delay(500);
void loop() {
if (SerialBT.available()) {
char rxdata = SerialBT.read();
Serial.write(rxdata);
if (rxdata == '1') digitalWrite(25, !digitalRead(25));
a24356789
Postby a24356789 » Mon Dec 07, 2020 2:47 am
Users browsing this forum: No registered users and 109 guests
