ESP-WROVER-KIT V3 physical dimensions
Re: ESP-WROVER-KIT V3 physical dimensions
Ok, so it is possible to calibrate the viewer using the measurements given in the DFX itself. All good.
Espressif - now that you have released Wrover Kit v4.1, would it be possible for you to publish the DXF for that as well? Ideally, drawings for these things should be available at the same place as the schematics, i.e. here.
In general, why not publish the drawings at the same time as the schematics, always?
Bump.
@ESP_igrr There are still no drawings with the dimensions to find for the dev boards.
Like permal said, these drawings should/could be uploaded to docs.espressif.com.
- ESP_krzychb
- Contact:
Hi permal and Cellie,
ESP-WROVER-KIT V4.1 DXF is now uploaded to https://dl.espressif.com/dl/schematics/ ... T_V4.1.dxf. Update of link in the user guide will follow.
We are planning to add similar file to user guides for newly released boards.
The overall board dimensions together with board layout (but in PDF format) is included already for the ESP32-S2 boards in their user guides in Section Related Documents, e.g. https://docs.espressif.com/projects/esp ... -documents
Users browsing this forum: Bing [Bot] and 94 guests
