I have a PCB where I need pullups on GPIO34-39, because I was not aware the software ones do not work. The documentation is very misleading, they should not be called GPIO at all, but I digress..
However, I also see this post that suggests you can workaround by using the RTC subsystem, but I was not able to get it to work using the Arduino framework. viewtopic.php?t=439
Is it possible to workaround at all with software, or am I forced to turn the board?
Thanks.
GPIO34-39 pullup workaround?
Re: GPIO34-39 pullup workaround?
Did you read that whole post you linked? They said they made a fix for it.
ESP_Sprite wrote: ↑Wed Nov 16, 2016 2:26 amFixed here: https://github.com/espressif/esp-idf/co ... 1f0b413ac4 (That commit already is in master, by the way, if you update esp-idf you should get the fixed code.)
As I mentioned, it does not appear to work. Either I am misunderstanding this change, or it is not used when using the Arduino framework.
I also tried using:
I also tried using:
- rtc_gpio_set_direction(myport , RTC_GPIO_MODE_INPUT_ONLY);
- rtc_gpio_pullup_en(myport);
No workaround for 34-39
Users browsing this forum: Corand and 270 guests
