AT command for light-sleep
I'm planning to change from ESP8266 to ESP32 using AT commands for communication and light-sleep mode. Unfortunately, I didn't find light sleep settings in AT instruction set. Do you have some SDK including it?
Thank you,
Jan
Thank you,
Jan
Re: AT command for light-sleep
How about the AT+SLEEP command of the latest master? https://github.com/espressif/esp-at/blo ... nds_Set.md
Thank you,
the bin files must be generated ?
I also found ESP32-WROOM-32 AT Bin V2.0 here
https://www.espressif.com/en/products/s ... t/resource
is the AT commands for light sleep included there ?
I have installed esp-idf and clone https://github.com/espressif/esp-at.git, but I got following error, when run idf.py menuconfig. How to solve this problem ?
CMake Error at CMakeLists.txt:78 (if):
if given arguments:
"NOT" "7934980f360fccb52ccfd496c067d675f987fcc8" "EQUAL"
Unknown arguments specified
cmake failed with exit code 1
if given arguments:
Did you change any files in project? Which commit of the project do you use?
Hello I didn't change any file in the project. I use last version of esp-at downloaded by "git clone https://github.com/espressif/esp-at.git" command yesterday. I use esp idf version 4.0.
Maybe some incompatibility in make programs, Python etc. ? I followed the link below, the example project "hello_world" works with the same command - idf.py menuconfig. Do you have any advice ?
https://docs.espressif.com/projects/esp ... index.html
Which version of cmake do you use? Mine is
cmake --version
cmake version 3.16.3
CMake suite maintained and supported by Kitware (kitware.com/cmake).
And can you run sed command in your PC?
Please provide all log, maybe the following command fail
execute_process(COMMAND sed -n /commit:/p ${ESP_AT_MODULE_CONFIG_DIR}/IDF_VERSION
OUTPUT_VARIABLE idf_commit
OUTPUT_STRIP_TRAILING_WHITESPACE)
cmake --version
cmake --version:
cmake version 3.13.4
execute_process(COMMAND sed -n /commit:/p ${ESP_AT_MODULE_CONFIG_DIR}/IDF_VERSION:
'execute_process' is not recognized as an internal or external command,
operable program or batch file.
I can't run sed command on my windows 10 OS
I have installed idf version 3.3 instead of latest version 4.2, but make menuconfig throw this error:
dell@JAN-NB MINGW32 ~/esp/esp-at
$ make menuconfig
Makefile:29: There is no module_config/module_wroom-32,Using module_config/modul e_esp32_default
The following Python requirements are not satisfied:
click>=5.0
pyelftools>=0.22
The recommended way to install a packages is via "pacman". Please run "pacman -S s <package_name>" for searching the package database and if found then "pacman - S mingw-w64-i686-python2-<package_name>" for installing it.
NOTE: You may need to run "pacman -Syu" if your package database is older and ru n twice if the previous run updated "pacman" itself.
Please read https://github.com/msys2/msys2/wiki/Using-packages for further infor mation about using "pacman"
Alternatively, you can run "C:/msys32/mingw32/bin/python.exe -m pip install --us er -r C:/msys32/home/dell/esp/esp-idf/requirements.txt" for resolving the issue.
make: *** Žádné pravidlo jak vyrobit cíl „check_python_dependencies“ potřebný pr o „menuconfig“. Konec.
$ make menuconfig
click>=5.0
pyelftools>=0.22
I have tried the ESP32-WROOM-32 AT Bin V2.0 AT+SLEEP commands. The power consumption is always the same for AT+SLEEP=1 and AT+SLEEP=2. Its about 29mA average in station mode connected to AP. Moreover AT+WAKEUPGPIO doesn´t work anymore... so I suppose the AT+SLEEP=1 is not implemented![Sad :-(](./images/smilies/icon_e_sad.gif)
Users browsing this forum: Baidu [Spider], jwachsmuth and 90 guests
