I have a question about UDP multicast.
Execute AT + CIPSTART = "UDP", "192.168.0.2", 0, 12345, 2 and OK will be displayed on the serial monitor. When I send UDP packets with PacketSender, + IPD, 5, hello is displayed.
When AT + CIPSTART = "UDP", "239.192.1.2", 0, 12345, 2 is executed, the serial monitor displays OK, and it is considered that the socket was correctly created. However, the PacketSender does not display + IPD when sending UDP packets to a multicast address.
Does AT firmware not support multicast?
Also, I don't want to use AT + MDNS.
I use google translation.
Thank you.
Receive multicast packets with AT + CIPSTART
Re: Receive multicast packets with AT + CIPSTART
It seems that ESP32 AT does not support multicast for now, maybe it should be added in the future.
Please try it again using the attachment
- esp-at.bin.zip
- (861.68 KiB) Downloaded 524 times
Thanks Helen L and xcguang.
I understand that ESP-AT does not support multicast.
Using the given bin file, the AT + CIPSTART command definitely received the multicast.
Hi akarg96,
thanks for your feedback, we will sync at GitHub ASAP, if you have any question about esp-at, you can report it at https://github.com/espressif/esp-at/issues
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 133 guests
