Hello All,
Am able to put ESP32 in Auto light sleep mode when am working in WiFi STA mode, will it same possible to do same power save when am using ESP32 WiFi as AP and using SP32 BLE, please help us to impliment power save when using WiFi AP and BLE
Please reply as soon as possible
Whether it is possible to use Auto Light sleep or other power save in WiFi AP mode and BLE
Re: Whether it is possible to use Auto Light sleep or other power save in WiFi AP mode and BLE
Regards
Divakara G R
Divakara G R
I am facing the some problem ... hopefully someone will be able to offer a solution soon ...
Same problem you are facing and you are using both Ap nd STA?ALNUA_1988 wrote: ↑Wed Dec 25, 2019 12:28 pmI am facing the some problem ... hopefully someone will be able to offer a solution soon ...
Regards
Divakara G R
Divakara G R
BT/BLE on ESP32 only supports auto light sleep when using external 32kHz crystal.
https://docs.espressif.com/projects/esp ... ower-clock
Than yousachin0x18 wrote: ↑Thu Dec 26, 2019 8:16 amBT/BLE on ESP32 only supports auto light sleep when using external 32kHz crystal.
How much power ESP32 will consume while BT/BLE in sleep (while auto light sleep enabled) because am getting 10mA not getting less than that
Regards
Divakara G R
Divakara G R
Hi Divakara GR, we do not suppor WIFI AP power safe mode, meanwhile we have BLE power save mode, u can find it here https://docs.espressif.com/projects/esp ... ht%20sleepdivakara G R wrote: ↑Fri Dec 20, 2019 5:34 amHello All,
Users browsing this forum: No registered users and 86 guests
