ESP32-D0WD with OV2640 camera.
Hairyloon
Postby Hairyloon » Wed Oct 02, 2019 5:09 pm
I've been trying to get one of these ESP32-Cam modules to work without success.
The first problem is that it keeps giving me "Brownout detector was triggered". Usually, if I leave it running then it settles down and gives me some other error: usually "camera probe failed with error 0x20001", but I've also had "camera: failed to set frame size e (4745) camera demo: camera init failed with error 0x20002" on one of them.
I'm currently trying "esp-who" from https://robotzero.one/esp32-camera-module/ but that one won't settle down out of the brown out cycle.
I'm reasonably sure that it has plenty of power. I'll find a meter in a mo and check the voltages...
pushtoopen
Re: ESP32-D0WD with OV2640 camera.
Postby pushtoopen » Sun Oct 06, 2019 6:38 am
I was able to get esp-CAM it working electrically with this tutorial: https://randomnerdtutorials.com/esp32-c ... duino-ide/
I use this cable to flash to it:
https://www.amazon.com/Converter-Termin ... 06ZYPLFNB/
I highly recommend the esp-eye only because of the additional ram built into the board. It's likely to have better luck with power issues and consistent working capability.
Hairyloon
Postby Hairyloon » Mon Oct 14, 2019 8:34 pm
It turns out I was mistaken about having plenty of power: gave it to a friend to try and it worked perfectly fine, brought it home and it is still flaky.
The only significant difference appears to be the power source...
Hairyloon
Postby Hairyloon » Fri Oct 18, 2019 7:29 am
Or perhaps not. I've now tried a power source that I have complete confidence in and it works, some of the time, for short periods...
I perhaps think we did not do a long enough test run at my friends.
The question now is of whether it is simply a defective board. Any suggestions on how to test it?
Hairyloon
Postby Hairyloon » Fri Jan 24, 2020 2:23 pm
The power issue appears to be solvable with a big fat capacitor. There was a post on the Random Nerd tutorial suggesting 1000μF which seems like a heck of a lot, but I had one to had and it worked fine.
I tried a 100μF and it didn't, though I was getting "camera not recognised" errors rather than brownouts.
I don't know if this helps anybody to work out what's going on...
Users browsing this forum: No registered users and 57 guests
