is there any example code related to os_tick_start and os_tick_handler.
thanks,
Madhu
tick example code
Re: tick example code
I'm not aware of functions called os_tick_start and os_tick_handler in an esp-idf context.
If the goal is to use timers then esp-idf does offer timer support. See https://docs.espressif.com/projects/esp ... timer.html
There is also the FreeRTOS Timer API. See https://docs.espressif.com/projects/esp ... #timer-api
And there's also the esp_timer API described at https://docs.espressif.com/projects/esp ... timer.html with an example of it's usage at https://github.com/espressif/esp-idf/tr ... /esp_timer
Users browsing this forum: No registered users and 178 guests
