Anyone interested in Arduino Environment?
DAFlippers
Re: Anyone interested in Arduino Environment?
Postby DAFlippers » Sun Jan 10, 2016 4:17 pm
I have loaded up Mikhail's Unofficial Development Kit for Espressif ESP32 version 0.0.6 and SDK example compiles without error. Taking the toolchain into the Arduino environment with a simple 'Hello World' sketch fails in the same way Rudi described.
C:\Program Files (x86)\Arduino\hardware\espressif\ESP31B\cores\esp31b\core_esp31b_noniso.c: In function 'dtostrf':
C:\Program Files (x86)\Arduino\hardware\espressif\ESP31B\cores\esp31b\core_esp31b_noniso.c:180:9: internal compiler error: Segmentation fault
         rounding *= 10.0;
I'm building on win 10 machine. Any thoughts?
David
ESP_Me-no-dev
Postby ESP_Me-no-dev » Sun Jan 10, 2016 8:26 pm
this seems to be connected to the toolchain you are using (the one in that dev kit).
If you go by the instructions from espressif, then it should all go nice and dandy :)
DAFlippers
Postby DAFlippers » Sun Jan 10, 2016 8:43 pm
The strange thing is that I used the toolchain that successfully built in Eclipse.
I'll have to build the toolchain a different way and see if the fault goes away.
David
ESP_Me-no-dev
Postby ESP_Me-no-dev » Mon Jan 11, 2016 10:47 am
I can also remove the offending function but that would not really be a fix now would it :)
We are beta testers so we are expected to get bugs :) Let's hope we resolve them :)
Keep me posted on that problem please.
BTW I'm using Eclipse as well to build all my Arduino stuff, but ran tests on the IDE as well. Are you saying that code compiles in Eclipse but not in ArduinoIDE?
DAFlippers
Postby DAFlippers » Mon Jan 11, 2016 8:36 pm
Yes simple hello world sketch failed to compile in Arduino but compiled in Eclipse. I'm now in Switzerland so might not have time to build environment on my laptop until I get back at the end of the week but I'll keep you informed.
David
ESP_Me-no-dev
Postby ESP_Me-no-dev » Tue Jan 12, 2016 11:44 am
Maybe the community can help here :)
I have the toolchain for OS X that I can share if someone needs it. Can you guys share a working toolchains for Windows and Linux?
Postby rudi ;-) » Tue Jan 12, 2016 9:52 pm
me-no-dev wrote:Maybe the community can help here :)
because: "Segmentation fault
rounding *= 10.0;
in windows / arduino ide with the UO xtensa-esp108-elf pack.
what was your config make calling from in OS X?
have you used in gcc configure
--enable-decimal-float=yes
think, that it will be.
( just in time try to build a fresh test toolchain from scratch in w32 and w64 for using i686-pc-mingw32)
ESP_Me-no-dev
Postby ESP_Me-no-dev » Wed Jan 13, 2016 3:36 pm
I went by the official instructions on the ESP32_RTOS repo, so whatever is defined there is working fine on OSX in both the IDE and Eclipse :)
git clone -b esp108-1.21.0 git://github.com/jcmvbkbc/crosstool-NG.git
cd crosstool-NG
./bootstrap && ./configure --prefix=`pwd` && make && make install
./ct-ng xtensa-esp108-elf
./ct-ng build
Here is mine :)
http://static.ficeto.com/xtensa-esp108-elf-osx.zip
ESP_Me-no-dev
Postby ESP_Me-no-dev » Sun Jan 17, 2016 1:52 am
It's the fourth day that I have been trying to build a toolchain for windows :)
I don't know how you guys use that OS for any development, but since you do, I'll give it another few days :D
If anyone has a recipe, I would love to give it a go.
ESP_Me-no-dev
Postby ESP_Me-no-dev » Mon Jan 18, 2016 2:23 pm
Windows 64 Toolchain: http://static.ficeto.com/xtensa-esp108-elf-cygwin64.zip << Needs https://cygwin.com/setup-x86_64.exe installed (defaults are fine) and "C:\cygwin64\bin" added to Path
Users browsing this forum: No registered users and 110 guests
