I am using the ESP-WROOM-32 module programming with Arduino in windows.
I want to get the Token ID of Firebase to connect, I do the POST, the server responds to me ok, but when I want to read the answer the program hangs and stops executing more code.
#include <WiFiClientSecure.h>
#include <HTTPClient.h>
const char* ssid = "...";
const char* password = "...";
void setup()
Serial.begin(115200);
delay(10);
// We start by connecting to a WiFi network
Serial.println();
Serial.println("************* Firebase_token3 *****************");
Serial.print("Connecting to ");
Serial.println(ssid);
WiFi.begin(ssid, password);
delay(500);
Serial.print(".");
Serial.println("");
Serial.println("WiFi connected");
Serial.println("IP address: ");
void loop()
HTTPClient http;
Serial.println("[HTTP] Iniciando...\n");
http.begin("https://www.googleapis.com/identitytool ... sword?key=......");
http.addHeader("HOST","www.googleapis.com");
http.addHeader("Content-Length","82");
http.addHeader("Content-Type","application/json");
int httpCode = http.POST("{\"email\":\"...@....\",\"password\":\"......\",\"returnSecureToken\":true}");
if ( httpCode > 0 )
Serial.print("Codigo: ");
Serial.println(httpCode); // Up here all right, I can see 200 in the console
String respuesta = http.getString();
Serial.println(respuesta); // This line of code is never executed
Serial.println("Exito?");
else
Serial.println("Error comunicacion HTTP.... ");
http.end();
delay(5000);
http.getString
Re: http.getString
I have the same issue but nos solution yet.
Since the problem seems to have existed for quite some time, but no solution has been published yet, I assume that there is no interest in a solution.
Re: http.getString
I have the same problem with an ESP8266 in the same place in the code. The problem with me is, if the server responds with 200, the response payload e.g. due to network problems does not arrive at the client. In my application currently only a restart of the ESP helps. I would also be interested in another solution.
Users browsing this forum: No registered users and 87 guests
