Hi all.
I am trying yo setup the at-commands module by flashing the esp-at.bin into the esp32 flash. However, I've trie to follow all the instructions on AT commands PDF and also some videos, but nothing works yet.
In the last AT version (https://www.espressif.com/en/support/download/at - V1.13) the avaiable bin files are:
-> at_customize;
-> blank;
-> esp-at;
-> factory;
-> partitions_at;
-> phy_init_data.
Which files I must download to esp, and in what address?
If someone can explain, I will be very aprecciated .
Regards.
Unable to setup esp AT commands bin
Re: Unable to setup esp AT commands bin
Have you looked at section 1.2 of the AT documentation?
Definitely.
But it's really not clarifying to what I should download at what addr...
The flashing addresses are in /ESP32_AT_BIN/download.config.
ESP_igrr wrote:The flashing addresses are in /ESP32_AT_BIN/download.config.
Ok, I didn't notice that. That helps me a lot!
I successfully downloaded the binaries, as you can see in the module's response in my serial monitor:
However, the module doesn't answer the "AT"+CR+LF echo test. The initialization is correct?
Hi all.
Problem solved
The default serial for AT commands are not the same that show logs and download the bin. There is another serial for that.
All is working fine now.
Thanks a lot for the help.
Problem solved
Can you post how you accomplished this task -- I am in the same boat
Hi guys. It's basically open the flash addresses in /ESP32_AT_BIN/download.config (open this as a text file). After, be careful to use serial 2 to send and receive AT commands, not the main serial (those standard for dev kits).
Users browsing this forum: ESP_Sprite and 84 guests
