FreeRTOS startup times
tuupola
Postby tuupola » Fri Apr 20, 2018 4:09 am
What are the expected startup times with ESP32 and FreeRTOS. I made a a test program which simply drives GPIO_NUM_12 high. When checking with scope it takes around 690ms for the pin to go high after power has been applied.
void app_main()
    gpio_pad_select_gpio(GPIO_NUM_12);
    gpio_set_direction(GPIO_NUM_12, GPIO_MODE_OUTPUT);
    gpio_set_level(GPIO_NUM_12, 1);
    xTaskCreatePinnedToCore(dummy_task, "Dummy", 2048, NULL, 1, NULL, 1);
This seems a bit high to me. Is there anything I can do to shorten the startup time? Or maybe I am hit with the spurious watchdog reset bug mentioned in ECO and workarounds doc. I do not see any watchdog reset message in the console though.
Mika Tuupola
https://appelsiini.net/
Users browsing this forum: Baidu [Spider] and 117 guests
