AC to DC converters for ESP32
Tommmmms
Postby Tommmmms » Sat Apr 14, 2018 9:35 pm
I will be using the ESP32 to dim an AC mains powered light fixture.
This means, the ESP32 can be powered by a 3.3V generated by a 110AC->5VDC power converter followed by a 5V->3.3V LDO that I already have on my ESP32 breakout board.
Questions:
1. If I plan to commercialize this product, should I keep the 110VAC->5VDC power circuity on a separate board than the ESP32?
2. I see a handful of cheap 110VAC->5VDC on Aliexpress for <$1 shipped from China. Anyone familiar with these AC->DC converters and whether those have a chance of passing the UL tests
How would you approach instituting this 110VAC->5VDC on the IoT system. Would you rather self-build the power circuit on the same PCB as the ESP32 or would you instantiate an UL-tested standalone power module on the same board.
I appreciate your help in advance.
Thanks,
Tom
Users browsing this forum: No registered users and 121 guests
