I've been using platform.io plugin for MVSC for all my ESP-IDF projects and it has worked well. However I now need to be on the latest release, so i switched to using the MSYS2 environment here:
https://espressif-docs.readthedocs-host ... setup.html
I really like this setup but now cannot figure out how to get MVSC to work like it did with platform.io.
I have looked for a solution to this, but after 2 hours of trying this and that from the web, I came up empty handed.
It would be great if espressif would add a section to the install guide along with using Eclipse as well, because I find using MVSC just as great.
If anyone has pulled this off, would some kind sole share a step by step guide to help me please.
ESP-IDF, MSYS2, and Visual Studio Code
Re: ESP-IDF, MSYS2, and Visual Studio Code
@WiFive, Thank you so much for that!!! It worked like a charm.
For anyone else, this tip will help speed up the make process.
In the tasks.json file, go to the "build app" section, and change it to this.
"label": "build app",
"group": "build",
"command": "make",
"type": "shell",
"args": [
"-j8",
"app"
"group": "build",
"command": "make",
"type": "shell",
"args": [
"-j8",
"app"
That's insane... I must try that. I understand this would be pure non arduino IDF ESP framework with C/C++ code - right?
Yes! Its awesome, I am shocked that this is not part of their docs.That's insane... I must try that. I understand this would be pure non arduino IDF ESP framework with C/C++ code - right?
Users browsing this forum: Baidu [Spider], Google [Bot] and 82 guests
