How to keep DAC output level during deepsleep?
temp4eb
Postby temp4eb » Tue Feb 06, 2018 9:33 am
Hi all,
I want to know if it is possible to achieve DAC keeping output voltage level during the deepsleep?For example,GPIO25 kept 2V level during the deepsleep.The Pins of DAC should be RTCIO,right?Thanx!
temp4eb
Re: How to keep DAC output level during deepsleep?
Postby temp4eb » Fri Feb 09, 2018 4:11 am
According to the document:
When configured as RTC GPIOs, the output pads can still retain the output level value when the chip is in
Deep-sleep mode, and the input pads can wake up the chip from Deep-sleep.
But I did not find any way to achieve this..............
WiFive
Postby WiFive » Fri Feb 09, 2018 4:24 am
You probably need ulp to use dac otherwise only latched digital outputs
Users browsing this forum: esp32New956832 and 87 guests
