Using ESC (Electronic Speed Control) with ESP32
meslin
Postby meslin » Tue Dec 26, 2017 6:06 pm
Hi all,
I would like to know how to control a brushless motor with ESC using ESP32. Is there a library? I used Servo.h to control them with Arduino, but a could not find a library like that to use with ESP32. Can you help me, please!
Thanks in advanced!
Alex
ESP_igrr
Re: Using ESC (Electronic Speed Control) with ESP32
Postby ESP_igrr » Wed Dec 27, 2017 8:23 pm
You can generate a PPM signal needed by ESCs using a variety of ways on the ESP32. RMT peripheral, which has 8 channels, is a good default choice..
clarkster
Postby clarkster » Fri Dec 29, 2017 4:09 pm
Also try using the LED PWM peripheral. It's simple to use. The ledc example included with the ESP-IDF gives you a great starting point.
meslin
Postby meslin » Tue Jan 02, 2018 11:58 pm
Hi ESP_igrr,
I forgot to mention that I'm totally new to ESP32...
I googled for RMT peripheral and ESC and I got no results (sorry, I don't know what is RMT peripheral). Do you know a link for a tutorial?
Thanks!
Alex
JacktheRipper
Postby JacktheRipper » Sat Apr 17, 2021 9:22 pm
Brushless motors and the ESCs that drive them are very complex. The discussion above falls well short of providing enough information to get them to work with an ESP32. With a standard Arduino, this complexity is handled within the ESC.h library which uses the Servo.h library to arm and then set speeds for the motor. Unfortunately, these are avr-only libraries, and the ESP32 does not seem to have equivalent ones, in particular the ESC.h library. It's much more complicated than just sending a PWM signal to the device. In ESC.h, there's a specific arming command that must be sent first, then specific calls to set the speed of the motor. This tailors the resulting PWM signal in a specific, very complicated way. I could find no equivalent library for the ESP32.
JacktheRipper
Postby JacktheRipper » Tue Apr 20, 2021 1:21 pm
I did get this working, and posted what I did in another thread:
viewtopic.php?f=19&t=20450&p=75073#p75073
Users browsing this forum: No registered users and 81 guests
