I'm trying to work at this project.https://www.youtube.com/watch?v=9B_DaUx8Z-U&t=605s with this code included. I compiled with no problem or error.
But after the upload it seem the esp32s3 stop working. All the led don't turn on if connected and i can't upload new code.
I tried with two different boards ad game me the same problem.
Any ideas? Also for recover the two boards?
#include <WiFi.h>
#include <ESP32Servo.h>
#include <esp_now.h>
#include <DFRobotDFPlayerMini.h>
#include <Adafruit_Sensor.h>
#include <Adafruit_ADXL345_U.h>
#include <FastLED.h>
#include <Wire.h>
#define BUTTON_PIN 1
#define NEOPIXEL_PIN 10
#define NUM_PIXELS 8
#define I2C_SDA_PIN 5
#define I2C_SCL_PIN 6
#define DFPLAYER_RX 7
#define DFPLAYER_TX 8
uint8_t receiverAddress[] = {0x00, 0x00, 0x00, 0x00, 0x00, 0x00};
uint8_t soundBoardMAC[] = {0x00, 0x00, 0x00, 0x00, 0x00, 0x00}; // Sound effect board MAC
Adafruit_ADXL345_Unified accel = Adafruit_ADXL345_Unified(12345);
DFRobotDFPlayerMini dfPlayer;
CRGB leds[NUM_PIXELS];
unsigned long buttonPressStartTime = 0;
const unsigned long longPressThreshold = 1000;
const unsigned long veryLongPressThreshold = 5000;
const unsigned long extraLongPressThreshold = 8000;
enum Mode {
ONBOARD_SOUND,
WIRELESS_SOUND
Mode currentMode = ONBOARD_SOUND;
enum FadeState {
OFF,
FADING_ON,
ON,
FADING_OFF,
ALWAYS_ON,
BLAST
FadeState fadeState = OFF;
unsigned long fadeStartTime = 0;
const unsigned long fadeDuration = 500;
const int filterSize = 20;
float angleBuffer[filterSize] = {0};
int bufferIndex = 0;
const float movementThreshold = 0.8; // Increased sensitivity
const unsigned long angleCheckInterval = 50;
unsigned long lastAngleCheckTime = 0;
unsigned long blastStartTime = 0;
const unsigned long blastDuration = 1500; // 1.5 seconds
const unsigned long blastCooldown = 1000; // Cooldown between blasts
bool blastTriggered = false;
unsigned long lastBlastTime = 0;
void handleButtonPress();
void handleAccelerometer();
void handleNeoPixels();
void sendWirelessData(uint8_t data, const uint8_t *address);
float calculateMovingAverage(float newValue);
void setup() {
Serial.begin(115200);
pinMode(BUTTON_PIN, INPUT_PULLUP);
WiFi.mode(WIFI_STA);
Serial.println("WiFi initialized");
Serial.print("Controller MAC Address: ");
Serial.println(WiFi.macAddress());
if (esp_now_init() != ESP_OK) {
Serial.println("Error initializing ESP-NOW");
return;
Serial.println("ESP-NOW initialized");
esp_now_peer_info_t peerInfo = {};
memcpy(peerInfo.peer_addr, receiverAddress, 6);
peerInfo.channel = 0;
peerInfo.encrypt = false;
if (esp_now_add_peer(&peerInfo) != ESP_OK) {
Serial.println("Failed to add receiver peer");
return;
Serial.println("Receiver peer added");
memcpy(peerInfo.peer_addr, soundBoardMAC, 6);
Serial.println("Failed to add soundboard peer");
return;
Serial.println("Soundboard peer added");
Wire.begin(I2C_SDA_PIN, I2C_SCL_PIN);
if (!accel.begin()) {
Serial.println("No ADXL345 detected");
while (1);
Serial.println("ADXL345 initialized");
FastLED.addLeds<NEOPIXEL, NEOPIXEL_PIN>(leds, NUM_PIXELS);
FastLED.clear();
FastLED.show();
Serial.println("FastLED initialized");
Serial1.begin(9600, SERIAL_8N1, DFPLAYER_RX, DFPLAYER_TX);
if (!dfPlayer.begin(Serial1)) {
Serial.println("DFPlayer Mini not detected");
while (1);
dfPlayer.setTimeOut(500);
dfPlayer.volume(30);
Serial.println("DFPlayer Mini initialized");
void loop() {
handleNeoPixels();
void handleButtonPress() {
static int lastButtonState = HIGH;
int buttonState = digitalRead(BUTTON_PIN);
unsigned long currentTime = millis();
if (buttonState == LOW && lastButtonState == HIGH) {
buttonPressStartTime = currentTime;
} else if (buttonState == HIGH && lastButtonState == LOW) {
unsigned long pressDuration = currentTime - buttonPressStartTime;
if (pressDuration >= extraLongPressThreshold) {
currentMode = (currentMode == ONBOARD_SOUND) ? WIRELESS_SOUND : ONBOARD_SOUND;
Serial.print("Mode switched to: ");
Serial.println(currentMode == ONBOARD_SOUND ? "ONBOARD_SOUND" : "WIRELESS_SOUND");
} else if (pressDuration >= veryLongPressThreshold) {
if (fadeState == ALWAYS_ON) {
fadeState = OFF;
Serial.println("Exiting ALWAYS_ON mode");
} else {
fadeState = ALWAYS_ON;
Serial.println("Entering ALWAYS_ON mode");
} else if (pressDuration >= longPressThreshold) {
uint8_t data = 102;
sendWirelessData(data, receiverAddress);
Serial.println("Long press detected, data sent");
} else {
uint8_t data = 101;
Serial.println("Short press detected, data sent");
delay(200);
lastButtonState = buttonState;
void handleAccelerometer() {
if (currentTime - lastAngleCheckTime < angleCheckInterval) {
return;
lastAngleCheckTime = currentTime;
sensors_event_t event;
accel.getEvent(&event);
float angle = atan2(event.acceleration.y, event.acceleration.z) * 180 / PI;
float filteredAngle = calculateMovingAverage(angle);
static float lastFilteredAngle = 0;
if (abs(filteredAngle - lastFilteredAngle) < movementThreshold) {
return;
float accelerationChange = event.acceleration.x;
float yAngle = atan2(event.acceleration.x, event.acceleration.z) * 180 / PI;
float zAngle = atan2(event.acceleration.x, event.acceleration.y) * 180 / PI;
if (!blastTriggered && accelerationChange < -0.9 && abs(yAngle) < 45 && abs(zAngle) < 30) {
if (fadeState == ON) {
if (currentTime - lastBlastTime > blastCooldown) {
fadeState = BLAST;
blastTriggered = true;
blastStartTime = millis();
if (currentMode == WIRELESS_SOUND) {
sendWirelessData(13, soundBoardMAC);
} else {
dfPlayer.play(3);
Serial.println("BLAST activated");
lastBlastTime = currentTime;
lastFilteredAngle = filteredAngle;
if (filteredAngle >= 35 && fadeState == OFF) {
sendWirelessData(12, soundBoardMAC);
} else {
dfPlayer.play(2);
fadeState = FADING_ON;
fadeStartTime = millis();
Serial.println("Starting to fade on");
} else if (filteredAngle < 35 && fadeState == ON) {
sendWirelessData(11, soundBoardMAC);
} else {
dfPlayer.play(1);
fadeState = FADING_OFF;
Serial.println("Starting to fade off");
void handleNeoPixels() {
switch (fadeState) {
case OFF:
FastLED.clear();
FastLED.show();
break;
case FADING_ON:
if (currentTime - fadeStartTime < fadeDuration) {
int brightness = map(currentTime - fadeStartTime, 0, fadeDuration, 0, 255);
for (int i = 0; i < NUM_PIXELS; i++) {
leds[i] = CRGB(brightness, brightness, brightness);
FastLED.show();
} else {
leds[i] = CRGB(255, 255, 255);
FastLED.show();
fadeState = ON;
Serial.println("Fade on complete");
break;
case ON:
FastLED.show();
break;
case FADING_OFF:
int brightness = map(currentTime - fadeStartTime, 0, fadeDuration, 255, 0);
FastLED.show();
} else {
FastLED.clear();
FastLED.show();
fadeState = OFF;
Serial.println("Fade off complete");
break;
case ALWAYS_ON:
FastLED.show();
break;
case BLAST:
if (currentTime - blastStartTime < blastDuration) {
int flicker = random(100, 150); // Adjust brightness for darker yellow
if (random(3) == 0) {
leds[i] = CRGB(flicker, flicker / 2, 0); // Darker yellow with occasional orange flicker
} else {
leds[i] = CRGB(flicker, flicker, flicker); // White with flicker
FastLED.show();
delay(50); // Adjust flicker speed
} else {
FastLED.clear();
FastLED.show();
fadeState = ON;
Serial.println("BLAST complete");
break;
void sendWirelessData(uint8_t data, const uint8_t *address) {
esp_now_send(address, &data, sizeof(data));
float calculateMovingAverage(float newValue) {
static float sum = 0;
static int count = 0;
static float readings[filterSize];
sum -= readings[bufferIndex];
readings[bufferIndex] = newValue;
sum += readings[bufferIndex];
bufferIndex = (bufferIndex + 1) % filterSize;
count = min(count + 1, filterSize);
return sum / count;
