Problem on IDE Eclipse
Valter
Postby Valter » Thu Nov 21, 2024 5:22 pm
Hallo at every one,
I just installed IDE Eclipse and at the end I add ESP IDF from the web 5.3.1.
When I try to start, I import an example "Hello World", but to build I have this error message.
CMake Error: CMake was unable to find a build program corresponding to "MinGW Makefiles". CMAKE_MAKE_PROGRAM is not set. You probably need to select a different build tool.
CMake Error: CMAKE_C_COMPILER not set, after EnableLanguage
I forget something? Need to install any other tools?
Thank you in advance,
Valter
Users browsing this forum: No registered users and 175 guests
