rst:0x10 (RTCWDT_RTC_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT) flash read err, 1000
allan45287
Postby allan45287 » Thu Oct 17, 2024 7:48 pm
Hello guys! I'm having a problem trying to encrypt my ESP. My ESP is a "ESP32-WROOM-32".
I'll show you the step-by-step that I followed to encrypt my ESP.
espsecure.py generate_flash_encryption_key ./key.bin
espefuse.py --port (PORT) burn_key flash_encryption ./key.bin
espefuse.py --port (PORT) burn_efuse FLASH_CRYPT_CNT
espefuse.py --port (PORT) burn_efuse FLASH_CRYPT_CONFIG 0x0F
espsecure.py encrypt_flash_data --keyfile ./key.bin --address 0x1000 -o build/bootloader/bootloader_encrypted.bin build/bootloader/bootloader.bin
espsecure.py encrypt_flash_data --keyfile ./key.bin --address 0x8000 -o build/partition_table/partition-table-encrypted.bin build/partition_table/partition-table.bin
espsecure.py encrypt_flash_data --keyfile ./key.bin --address 0x10000 -o build/project_name_encrypted.bin build/project_name.bin
To flash my project, I use this code:
C:\Espressif\python_env\idf4.4_py3.11_env\Scripts\python.exe ..\..\..\..\..\..\Espressif\frameworks\esp-idf-v4.4.5\components\esptool_py\esptool\esptool.py -p COM3 -b 460800 --before default_reset --after hard_reset --chip esp32  write_flash --flash_mode dio --flash_size detect --flash_freq 80m 0x1000 build/bootloader/bootloader_encrypted.bin 0x8000 build/partition_table/partition-table-encrypted.bin 0x10000 build\project_name_encrypted.bin
The problem commes when I try doing:
idf.py --port <PORT> monitor
This is the output:
'C:\Espressif\frameworks\esp-idf-v4.4.5\tools\idf.py' '--port' 'COM3'"...
--- WARNING: GDB cannot open serial ports accessed as COMx
--- Using \\.\COM3 instead...
--- idf_monitor on \\.\COM3 115200 ---
ets Jun  8 2016 00:22:57
ets_main.c 371
ets_main.c 371
ets_main.c 371
ets_main.c 371
ets_main.c 371
ets_main.c 371
I am sorry if I am missing something, but I really don't know what is happening in here.
Users browsing this forum: Baidu [Spider] and 66 guests
