Event Loop Base issues
Fundeckhermit
Postby Fundeckhermit » Wed Oct 02, 2024 4:20 pm
I've been trying to implement the Event Loop Library. Posting and registering events using a hardcoded static string works fine.
When the string is dynamic and identical to the base it fails to trigger.
I'm registering an event using:
esp_event_handler_instance_register("COMMANDBASE1", 0, commandfunction, NULL, NULL);
And posting it with an hardcoded string works:
esp_event_post("COMMANDBASE1", 0, NULL, 0, portMAX_DELAY)
When I change the base to a char* variable containing "COMMANDBASE1" it fails:
This string is from UART so I cannot make it hardcoded.
esp_event_post(basevar, 0, NULL, 0, portMAX_DELAY)
With a hack and a lookup table I can trigger the event again:
inline esp_event_base_t filterEvents(char* eventBase)
    if(strcmp(eventBase, "COMMANDBASE1") == 0)
        return (esp_event_base_t)"COMMANDBASE1";
    return (esp_event_base_t)"UNKNOWN";
esp_event_post(filterEvents(basevar),0, NULL, 0, portMAX_DELAY)
How do I convert a char* to esp_event_base_t as the esp_event_post function only seems to work with hardcoded strings?
MicroController
Re: Event Loop Base issues
Postby MicroController » Wed Oct 02, 2024 5:47 pm
See e.g. the example at https://github.com/espressif/esp-idf/tr ... event_loop
It uses the provided macros to declare and define event bases.
Notice that an "event base" is not a string but actually only a pointer, i.e. a memory address. An event base is identified by this address only. Two strings will not live at the same address, unless they are identical compile-time constants/literals and merged into one by the compiler/linker.
Fundeckhermit
Postby Fundeckhermit » Thu Oct 03, 2024 7:49 am
Thank you for the reply,
Now it makes sense to me on what is happening under the hood.
So the only method of converting char* to a base address is by mapping?
I'll study the macro's a bit more, the documentation about them was quite sparse.
Users browsing this forum: Bing [Bot] and 106 guests
