WIFI Issues with ESP32-S3-WROOM-1 modules that don't have a CMIIT ID
tonystuart
Postby tonystuart » Wed Sep 18, 2024 2:44 pm
I use generic ESP32-S3-DevKitC boards as a sub-assembly in a product. These boards have an ESP32-S3-WROOM-1 module on them. I source them from a number of suppliers.
On some of these boards the WIFI doesn't work properly. It successfully scans for Access Points, but won't connect to an Access Point. In the following photo, the board on the left doesn't work. The board on the right works.
I found an earlier topic that describes a problem with being able to scan for Access Points but not connect:
viewtopic.php?t=32109
This earlier topic suggests touching the WIFI antenna with a finger while connecting. This works with my problem boards as well.
Looking at my boards carefully, I see a pattern. The boards that don't work have different markings on the ESP32-S3-WROOM-1 module than those that do work. In particular, the CMIIT ID is empty on the boards that don't work.
Also the onboard antenna on the non-working board on the left looks like a typical Meandered Inverted F Antenna (MIFA) while the antenna on the working board on the right has an extra meander.
I am using Full RF Calibration as described here:
https://docs.espressif.com/projects/esp ... ation.html
And here are the WIFI PHY settings from my sdkconfig:
CONFIG_ESP_PHY_CALIBRATION_AND_DATA_STORAGE=y
# CONFIG_ESP_PHY_INIT_DATA_IN_PARTITION is not set
CONFIG_ESP_PHY_MAX_WIFI_TX_POWER=20
CONFIG_ESP_PHY_MAX_TX_POWER=20
CONFIG_ESP_PHY_REDUCE_TX_POWER=y
CONFIG_ESP_PHY_ENABLE_USB=y
# CONFIG_ESP_PHY_ENABLE_CERT_TEST is not set
# CONFIG_ESP_PHY_RF_CAL_PARTIAL is not set
# CONFIG_ESP_PHY_RF_CAL_NONE is not set
CONFIG_ESP_PHY_RF_CAL_FULL=y
CONFIG_ESP_PHY_CALIBRATION_MODE=2
This leaves me with a number of questions:
  • Are ESP32-S3-WROOM-1 modules produced only by Espressif or by many suppliers?
  • What does the missing CMIIT ID mean? Is this an early version of the board? Should it even be available?
  • Is there a way to configure the WIFI or PHY to work around this problem?
Any ideas?
Thanks!
MicroController
Re: WIFI Issues with ESP32-S3-WROOM-1 modules that don't have a CMIIT ID
Postby MicroController » Wed Sep 18, 2024 11:03 pm
On some -C3 "Supermini" boards I found that I had to actually reduce the WiFi TX power from the default (20dBm?) (used esp_wifi_set_max_tx_power()) to be able to connect to a network. Probably due to a "sub-optimal" matching network and/or antenna on the board. IIRC, I could only go up to 11 or 13dBm before connection issues appeared. May be worth trying out.
tonystuart
Postby tonystuart » Thu Sep 19, 2024 12:16 am
Thanks... I'll give that a try.
Update: I tried reducing the max tx power and it connects. Very interesting... and a bit counterintuitive (at least for me)!
DahBenni
Postby DahBenni » Sun Dec 08, 2024 10:45 am
I also had the same issues and wanted to try esp_wifi_set_max_tx_power(40);
Then I found this post: https://esp32.com/viewtopic.php?t=41895
I simply started to unsolder / disconnected an external LED from GPIO Pin 21.
Surprise: It resolved my issues instantly :)
nhandt64
Postby nhandt64 » Wed Jan 22, 2025 6:46 am
I have the exact same custom board like you on the right, which also have CMIT ID. It however doesn't connect to my home Wifi as expected while the original ESP32 custom board just connect without any hassle.
I'm working with Arduino IDE + arduino-esp32 because I'm new to mcu programming in general, and I thought if the board is defected, or libraries doesn't really working (I have thought about switching to esp-idf but my college project doesn't give me abundant amount of time).
I spent almost a day getting this sorted out and finally I came to this post, what a relief (and funny).
I'm not sure about the GPIO soldering solution, but for now I think I just need to touch the Wifi antenna XD
Nhan Dang
CompEng undergraduate, Can Tho University
trungnhan6143 [at] gmail [dot] com
seba2122
Postby seba2122 » Fri Feb 14, 2025 8:43 am
I have the same issue? Did you ment to solve it? I have 4 of ESP S3 Chips with the same issue , they only connect when the transmission power is lowered. Is it a board design issue?
Users browsing this forum: No registered users and 54 guests
