WiFi list of duplicated SSID access points (AP)
ilangr
Postby ilangr » Wed Aug 21, 2024 10:39 am
We are having any issue when using ESP32-S3 chip. After integrating the SDK and implementing the WiFi capabilities, we faced a special case which we think isn't handled well.
In case there are two different APs (access points) that contain the same SSID, lets say "router_ex", the AP scan gives us both of them.
If we compare it to Mediatek chip for example (MT7697), in this case we get a single SSID AP.
Laptop or phones act the same and show you a single SSID and not two like we have in ESP.
My question is: Do we need to manually implement logic to choose which SSID to use (based on RSSI? based on previous connected MAC number? other considerations...?), or does the ESP SDK contain a built in solution for this case?
chegewara
Re: WiFi list of duplicated SSID access points (AP)
Postby chegewara » Wed Aug 21, 2024 7:22 pm
I believe the point is to give programmers flexibility to filter AP by bssid too, which you dont need on PC.
boarchuz
Postby boarchuz » Fri Aug 23, 2024 9:52 am
Station config has fields to control how the driver should select the best AP:
https://github.com/espressif/esp-idf/bl ... #L386-L387
Or you can use custom logic and specify the BSSID.
Users browsing this forum: adrianomunin, Bing [Bot], Google [Bot] and 74 guests
