ESP32S3, deep sleep wakeup and vtaskdelay()
jjones7432
Postby jjones7432 » Wed May 22, 2024 10:11 pm
vtaskdelay() causes the GPIO# assigned in esp_sleep_enable_ext0_wakeup(GPIO#, high) to immediately go high. (Behavior is observed via o-scope.) When the device goes to deep sleep, the device is immediately awaken with the wakeup cause "ext0 wakeup".
Removing the vtaskdelay() function, the GPIO# is remains low as designed. (Behavior is confirmed via o-scope.) This allows the expected "ext0 wakeup" in deep sleep to work properly, which the GPIO# is transitioned to high. (Behavior is confirmed via o-scope.)
Please advise how to make ext0_wakup work properly with vtaskdelay().
Thanks.
Re: ESP32S3, deep sleep wakeup and vtaskdelay()
Postby ESP_Sprite » Thu May 23, 2024 1:41 am
I doubt that's actually what's happening, given that vTaskDelay has absolutely nothing to do with interrupts, wakeup sources or GPIO. Can you post the code that replicates this?
jjones7432
Postby jjones7432 » Fri Jun 07, 2024 7:15 pm
Thanks for replying.
As you suggest, after more testing, it doesn't appear to be vTaskDelay() associated.
There are two deep sleep wakeups:
1. wakeup_ext0 - This wakeup if from a sensor driving GPIO1 to force a wakeup. This wakeup is behaving as expected, performing some operations, clearing the sensor, resetting the two wakeups and going back to deep_sleep. wakeup_ext0 is not triggered unless we deliberately trigger the sensor.
2. wakeup_timer - Our problem occurs during the processing. This wakeup is triggered when the time period expires and does a lot of wifi operations. We ensure that GPIO1 is not active before the device resets both wakeups and goes to sleep. However, GPIO1 goes active immediately and wakeup_ext0 is triggered. Wakeup_ext0 finishes and does not trigger again, since GPIO1 is not triggered by the sensor.
We only have these "false" triggering during the timer_wakeup and it's only once per timer_wakeup. Both wakeups run through the same GPIO setup.
Not sure what we can post to show the behavior. The o-scope only shows that the GPIO1 was low before going to sleep but went active during sleep for the wakeup_timer.
Any suggestion is appreciated.
Users browsing this forum: Baidu [Spider], Bing [Bot] and 105 guests
