PWM for low-cost ClassD audio amplifier
dj.petr
Postby dj.petr » Sat May 11, 2024 2:23 pm
Hi, everyone!
I´m new in ESP and I need to control duty of PWM by analogue signal connected to the internal ADC. I have this code:
const int analogInputPin = 36;
const int pwmOutputPin = 2;
void setup() {
  pinMode(analogInputPin, INPUT);
  ledcSetup(0, 78000, 10); // freq of PWM 78kHz, 10bit
  ledcAttachPin(pwmOutputPin, 0);
void loop() {
  int analogValue = analogRead(analogInputPin);
  ledcWrite(0, analogValue);
I watch the output of ClassD amplifier on a scope and theres a problem with aliasing on sinewave frequencies higher than cca 1kHz (input is sinewave with amplitude 1-4V with ofset voltage). So i have question, how to solve this, how to optimize code to run on a higher frequencies than 1kHz..
Thanks! ;-)
liaifat85
Re: PWM for low-cost ClassD audio amplifier
Postby liaifat85 » Sun May 12, 2024 1:57 pm
Implement an anti-aliasing filter on the PWM output signal to remove high-frequency components before it reaches the amplifier. This can help in reducing aliasing effects in the output signal.
Users browsing this forum: Baidu [Spider] and 72 guests
