ESPPROG ESP32S3
ACKHAN
ESPPROG ESP32S3
Postby ACKHAN » Sat Mar 09, 2024 12:40 am
I am trying to use ESP32S3 with platform IO , when i try to program with JTAG ESPPROG
[env:esp32-s3-devkitc-1]
platform = espressif32
framework = arduino
board = esp32-s3-devkitc-1
monitor_speed = 115200
upload_port = COM6
upload_protocol = esp-prog
debug_tool = esp-prog
debug_init_break = tbreak setup
This in my platformio.ini file
The terminal showing this error.
Configuring upload protocol...
AVAILABLE: cmsis-dap, esp-bridge, esp-builtin, esp-prog, espota, esptool, iot-bus-jtag, jlink, minimodule, olimex-arm-usb-ocd, olimex-arm-usb-ocd-h, olimex-arm-usb-tiny-h, olimex-jtag-tiny, tumpa
CURRENT: upload_protocol = esp-prog
Uploading .pio\build\esp32-s3-devkitc-1\firmware.bin
Open On-Chip Debugger v0.11.0-esp32-20220706 (2022-07-06-15:48)
Licensed under GNU GPL v2
For bug reports, read
debug_level: 1
adapter speed: 20000 kHz
adapter speed: 5000 kHz
Warn : Unexpected idcode after end of chain: 21 0x00000000
Warn : Unexpected idcode after end of chain: 53 0x00000000
Warn : Unexpected idcode after end of chain: 85 0x00000000
Warn : Unexpected idcode after end of chain: 117 0x00000000
Warn : Unexpected idcode after end of chain: 149 0x00000000
Warn : Unexpected idcode after end of chain: 181 0x00000000
Warn : Unexpected idcode after end of chain: 213 0x00000000
Warn : Unexpected idcode after end of chain: 245 0x00000000
Warn : Unexpected idcode after end of chain: 277 0x00000000
Warn : Unexpected idcode after end of chain: 309 0x00000000
Warn : Unexpected idcode after end of chain: 341 0x00000000
Warn : Unexpected idcode after end of chain: 373 0x00000000
Warn : Unexpected idcode after end of chain: 405 0x00000000
Warn : Unexpected idcode after end of chain: 437 0x00000000
Warn : Unexpected idcode after end of chain: 469 0x00000000
Warn : Unexpected idcode after end of chain: 501 0x00000000
Warn : Unexpected idcode after end of chain: 533 0x00000000
Warn : Unexpected idcode after end of chain: 565 0x00000000
Warn : Unexpected idcode after end of chain: 597 0x00000000
Warn : Unexpected idcode after end of chain: 629 0x00000000
Error: double-check your JTAG setup (interface, speed, ...)
Error: esp32s3.cpu0: IR capture error; saw 0x00 not 0x01
Error: Unexpected OCD_ID = 00000000
Warn : target esp32s3.cpu0 examination failed
Warn : target esp32s3.cpu1 examination failed
Error: JTAG scan chain interrogation failed: all zeroes
Error: Target not examined yet
embedded:startup.tcl:1184: Error: ** Unable to reset target **
in procedure 'program_esp'
in procedure 'program_error' called at file "C:/Users/alikh/.platformio/packages/tool-openocd-esp32/share/openocd/scripts/target/esp_common.cfg", line 104
at file "embedded:startup.tcl", line 1184
*** [upload] Error 1
========================================== [FAILED] Took 2.76 seconds ==========================================
* The terminal process "C:\Users\alikh\.platformio\penv\Scripts\platformio.exe 'run', '--target', 'upload'" terminated with exit code: 1.
* Terminal will be reused by tasks, press any key to close it.
Please help if you can.
ACKHAN
Re: ESPPROG ESP32S3
Postby ACKHAN » Sat Mar 09, 2024 1:53 am
I have sorted this problem myself thanks.
Users browsing this forum: Google [Bot] and 70 guests
