I'm trying to create an Espressif project with the Eclipse plugin, but I'm receiving this error message:
java.lang.NoClassDefFoundError: org/eclipse/tools/templates/core/IGenerator
at com.espressif.idf.ui.handlers.NewProjectHandler.execute(NewProjectHandler.java:25)
at com.espressif.idf.ui.wizard.NewIdfProjectMainWizard$1.run(NewIdfProjectMainWizard.java:34)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:40)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:132)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:4046)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3662)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$5.run(PartRenderingEngine.java:1155)
at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:342)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1046)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:155)
at org.eclipse.ui.internal.Workbench.lambda$3(Workbench.java:648)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:555)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:173)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:152)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:208)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:136)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:104)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:402)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:255)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:77)
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.base/java.lang.reflect.Method.invoke(Method.java:568)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:651)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:588)
at org.eclipse.equinox.launcher.Main.run(Main.java:1459)
Caused by: java.lang.ClassNotFoundException: org.eclipse.tools.templates.core.IGenerator cannot be found by com.espressif.idf.ui_1.0.1.202310270725
at org.eclipse.osgi.internal.loader.BundleLoader.generateException(BundleLoader.java:541)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass0(BundleLoader.java:536)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:416)
at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:168)
at java.base/java.lang.ClassLoader.loadClass(ClassLoader.java:525)
... 27 more
I already did the tool installation.
Thank you
Creating a espressif project - ECLIPSE PLUGIN
Re: Creating a espressif project - ECLIPSE PLUGIN
Here is a similar type of problem: https://esp32.com/viewtopic.php?t=13923
Users browsing this forum: No registered users and 66 guests
