strptime - what am I doing wrong?
dbaicz
Postby dbaicz » Mon Nov 06, 2023 11:09 am
On ESP32 I need to convert a date and time in the form "10/23/2023 11:37:15 AM" to a 24 hour format in the form "23/10/2023 11:37:15". I use strptime function, but it completely ignores the AM/PM flag and returns the time as if the source time contained PM.
Example:
#include <time.h>
struct tm ts;
char output[100];
void setup() {
  Serial.begin(115200);
  delay(1000);
  char input[] = "10/23/2023 11:37:15 AM";
  Serial.printf("Input is '%s'\n", input);
  strptime(input, "%m/%d/%Y %I:%M:%S %p", &ts);
  //strptime(input, "%m/%d/%Y %r", &ts); // the same problem
  // test result
  strftime(output, sizeof(output), "%d/%m/%Y %H:%M:%S", &ts);
  Serial.printf("Output is '%s'\n", output);
void loop() {
Result is '23/10/2023 23:37:15'. I do not know what I am doing wrong. Anyone have any ideas?
Shoyur
Re: strptime - what am I doing wrong?
Postby Shoyur » Tue Nov 07, 2023 6:56 pm
maybe there is a better solution, sorry im not an expert, but i was also not able to use a tag to recognize its not PM in the tm structure.
so why not parse your string and manually put the values back to your tm values.
i was thinking maybe the string length can vary (the day or the hour could have a single character).
#include <time.h>
struct tm ts;
char output[100];
void setup() {
  delay(1000);
  int mo, d, y, h, m, s;
  char value[3];
  sscanf(input, "%d/%d/%d %d:%d:%d %2s", &d, &mo, &y, &h, &m, &s, value);
  if (strcmp(value, "PM") == 0 && h != 12) {
    h += 12;
  } else if (strcmp(value, "AM") == 0 && h == 12) {
    h = 0;
  ts.tm_sec = s;
  ts.tm_min = m;
  ts.tm_hour = h;
  ts.tm_mday = d;
  ts.tm_mon = mo - 1;
  ts.tm_year = y - 1900;
  // test result
void loop() {
mbratch
Postby mbratch » Wed Nov 08, 2023 7:29 pm
As far as I can tell, you aren't calling the functions wrong. That would lead me to think there could be a bug in the library perhaps.
I am not using Arduino but ESP-IDF. I will give this a try on that system and see what I get.
MicroController
Postby MicroController » Wed Nov 08, 2023 9:38 pm
"%p" depends on the current locale, which may also define %p to be empty. Maybe the (default) locale is not set to what you need.
qubdtq
Postby qubdtq » Thu Apr 25, 2024 11:43 pm
In case it's helpful, I believe this was a bug and is now fixed:
https://github.com/espressif/arduino-esp32/issues/9184
Users browsing this forum: ShreyAcharya and 92 guests
