ESP32 with small PCB searched.
I'm Robert from germany. I searching a ready to use small PCB with a ESP32 on it. Do you have a advice where I can find such?
It ist for a RC-Car(1:24) project.
It isn't necessary to have all pins outside, because I would like to use a bus system.
https://de.aliexpress.com/store/product ... 53522.html This looks good but it has a USB-Chip on it, witch I don't need i think.
Thank's for your help.
Robert
Robert
Re: ESP32 with small PCB searched.
Hello Robert. Have you already looked at the modules that do not have a DIP pinout? For example, the module you mentioned is based on the WROOM32 module, which is also obtainable separately.
Thats the smallest that I own:
https://www.tindie.com/products/onehors ... ent-board/
The photos don't really do it justice, its amazingly small while still full-featured. Not cheap though. Remember you'll have to set the flash to DOUT mode.
I am waiting for a module like this:
https://www.aliexpress.com/item/Hot-sel ... 40089.html
I placed the order a few days ago.
nice - you know, that the modul can't connect to a breadboard?lmarmisa wrote:I am waiting for a module like this:
( double pinheader pins left and right are nice but they are different signals from neighboring pin)
rudi
Yep, they look nice at first sight but I never use them because of this.nice - you know, that the modul can't connect to a breadboard?
You can solder two outer rows of pins on bottom side of board and two inner rows on toprudi ;-) wrote: nice - you know, that the modul can't connect to a breadboard?
Yes, I know. I will use a PCB solution. I want to explore low power consumption ESP32 designs using batteries, deep sleep and BLE.rudi ;-) wrote:nice - you know, that the modul can't connect to a breadboard?lmarmisa wrote:I am waiting for a module like this:
rudi
ah one row it wants to be put on the breadboard and the other row put from abovesintech wrote:You can solder two outer rows of pins on bottom side of board and two inner rows on toprudi ;-) wrote: nice - you know, that the modul can't connect to a breadboard?
very nice this modul becomes own special character.
then perhabs better, we connect wire from the board to the breadboard ?
Or we will take an adapter hole grid board for soldering the breakout adapter board
and then we wire the hole grid board to the breadboard -
i see - this is a good exercise for beginners
(After the exercise then:: we make then an adapter board for the hole grid board that fits on a breadboard too)
Users browsing this forum: No registered users and 76 guests
