timer is getting delayed due to some reason
kesha.modhia
Postby kesha.modhia » Tue Sep 05, 2023 9:30 am
During one exercise of blinking the led for 2 minutes
I used timer and created timer for 2 minutes and I set the led to blink for 120 seconds
after expiration it should stop the led, some how i noticed timer is getting delayed due to some events which i am not able to figure out
here I have attached some code
timer created
#define PAIR_LED_TIME_PERIOD pdMS_TO_TICKS( 120000 )
if ((xPairLedTimerHandle = xTimerCreate((const char *)"Pair Led Timer",PAIR_LED_TIME_PERIOD,
pdFALSE, NULL, PairLedTimerExpiredCallback)) == NULL ) {
DEBUG_LOGE(UART, TAG, "xPairLedTimerHandle creation failed");
timer started
if (xTimerStart(xPairLedTimerHandle,0) == pdPASS)
DEBUG_LOGI(UART, TAG, "*xPairLedTimerHandle* TIMER STARTED");
PairingWindowLedStatus(APP_STATUS_LED3);
DEBUG_LOGD(UART, TAG, "back");
Led blinking api
void PairingWindowLedStatus(uint8_t gpiono)
bool ON = 1, OFF = 0;
uint16_t counter,ticks = 600;
for(counter = 0; counter <= ticks ; counter++)
gw_gpio_level_set(gpiono,ON); //LED is turn ON
nlg_task_delay_ms(100);
gw_gpio_level_set(gpiono,OFF); //LED is turn OFF
DEBUG_LOGD(UART, TAG, "out of for");
Timer is taking more 20 sec to expire, I came to know form the callback invoked late
how do I debug the time taken by which process
Thanks in advance
tpbedford
Re: timer is getting delayed due to some reason
Postby tpbedford » Wed Sep 06, 2023 10:18 pm
  1. uint16_t counter,ticks = 600;
  2. for(counter = 0; counter <= ticks ; counter++)
  3. {
  4.     gw_gpio_level_set(gpiono,ON); //LED is turn ON
  5.     nlg_task_delay_ms(100);
  6.     gw_gpio_level_set(gpiono,OFF); //LED is turn OFF
  7.     nlg_task_delay_ms(100);
  8. }
This loop takes 0.2s to execute, and you execute it 600x - actually 601 times - so this block runs for 120.2s regardless of your timer value. (I don't know how accurate nlg_task_delay_ms() is, so perhaps it takes longer than 120.2s if this delay is not very accurate.)
What does PairLedTimerExpiredCallback() do? Does it kill the task that starts the timer and runs the LED loop?
kesha.modhia
Postby kesha.modhia » Thu Sep 07, 2023 5:48 am
Yes, PairLedTimerExpiredCallback() will OFF the blinking
so what shall I do for syncing the led and the timer for exact 120 seconds
tpbedford
Postby tpbedford » Thu Sep 07, 2023 5:52 am
How? Post the code for this.
One method is that your loop continues indefinitely (instead of 600 iterations) and also tests for a semaphore set by PairLedTimerExpiredCallback(). Once it detects the semaphore, it exits.
kesha.modhia
Postby kesha.modhia » Thu Sep 07, 2023 7:12 am
Here I have attached the code
static unsigned char Pair_Led;
void PairLedTimerExpiredCallback(void *p_arg){
DEBUG_LOGI(UART, TAG, "********************in PairLedTimerExpiredCallback");
Pair_Led = 1;
led_event(LED_DEVICE_PAIR);
void led_event (event_led event)
case LED_DEVICE_PAIR:
DEBUG_LOGI(UART, TAG, "LED_DEVICE_PAIR");
if(Pair_Led == 0){
APPSendingMessage(APP_E_HIGH_FREQUENCY, APP_STATUS_LED3,
APP_E_CONTINUOUSLY_BLINK);
}else{
APPSendingMessage(APP_E_SOLID_OFF,APP_STATUS_LED3,
Pair_Led = 0;
break;
ok-home
Contact:
Postby ok-home » Thu Sep 07, 2023 7:54 am
Hi
use xTaskDelayUntil
to form a delay
https://www.freertos.org/vtaskdelayuntil.html
tpbedford
Postby tpbedford » Thu Sep 07, 2023 7:58 am
Where does APPSendingMessage event go? Who is listening?
There's so much code you're not posting here it's impossible to work out how you actually intend this to work.
The LED loop runs in some task (the same one that starts the timer). The loop needs to check some condition so it knows when to stop. If you sending some message, the loop needs to poll for it, and when it receives the message it breaks the loop.
kesha.modhia
Postby kesha.modhia » Thu Sep 07, 2023 9:15 am
APPSendingMessage(APP_E_HIGH_FREQUENCY, APP_STATUS_LED3,APP_E_CONTINUOUSLY_BLINK);
Is the api to post the message in the led queue, which is one task ,is continously running in background to collect the led queue msg and run accordingly
PUBLIC void APPSendingMessage(unsigned char led_type, unsigned char led_number, unsigned char blink_number) {
APP_LedEvent sButtonEvent;
sButtonEvent.eLEDType = led_type;
sButtonEvent.BlinkNumber = blink_number;
sButtonEvent.u8LEDNumber = led_number;
if(nlg_queue_send(APP_LedmsgEvents, (void * )&sButtonEvent, 0)!= nlg_pass){
DEBUG_LOGE(UART, TAG, "APP_LedMsgEvent_queque send failed");
and runs according the event
vanBassum
Postby vanBassum » Thu Sep 07, 2023 9:22 am
Why not like this?
Its a bit speudo but you get the idea.
enum LedModes
	Off,
	Blink,
	On,
LedModes mode;
void Main()
	Timer.SetInterval(blinkSpeed);
	Timer.Start();
void TimerCallback
	if(mode == Off && GetLed() == 1)
		SetLed(0);
	if(mode == Blink)
		if(GetLed() == 1)
			SetLed(0);
		else
			SetLed(1);
	if(mode == On && GetLed() == 0)
		SetLed(1);
Or, this is probably more along the lines of what you want. (Didn't test)
It seems a bit overkill to run a task just to blink a LED.
typedef enum {
    LED_STATE_OFF,
    LED_STATE_ON,
    LED_STATE_BLINKING
} led_state_t;
void task_function(void *pvParameter) {
	led_state_t current_led_state = LED_STATE_BLINKING;
	bool pinState = false;
    while (1) {
		// Wait for a notification from the timer
		led_state_t requestedState;
        ulTaskNotifyTake(&requestedState, pdMS_TO_TICKS(500));	//blinking 1Hz
		//Change led mode if requested by notification
		if(requestedState != current_led_state)
			current_led_state = requestedState;
		if(current_led_state == LED_STATE_BLINKING)
			// Toggle the LED state
			pinState = !pinState;
			gpio_set_level(LED_GPIO_PIN, ledState);
		if(current_led_state == LED_STATE_ON)
			if(pinState == false)
				pinState = true;
				gpio_set_level(LED_GPIO_PIN, pinState);
		if(current_led_state == LED_STATE_OFF)
			if(pinState == true)
				pinState = false;
// Function to be executed when the timer expires
void timer_callback(TimerHandle_t xTimer) {
    BaseType_t xHigherPriorityTaskWoken = pdFALSE;
    // Notify the task
    xTaskNotifyFromISR(xTimerGetTimerDaemonTaskHandle(), 0, LED_STATE_OFF, &xHigherPriorityTaskWoken);
    // If xHigherPriorityTaskWoken is pdTRUE, a context switch should be requested
    if (xHigherPriorityTaskWoken == pdTRUE) {
        portYIELD_FROM_ISR();
void app_main() {
    // Configure the LED GPIO pin
    gpio_config_t io_conf;
    io_conf.pin_bit_mask = (1ULL << LED_GPIO_PIN);
    io_conf.mode = GPIO_MODE_OUTPUT;
    gpio_config(&io_conf);
    // Create a task
    xTaskCreate(task_function, "task", 2048, NULL, 5, NULL);
    // Create a timer, expire after 20sec
    TimerHandle_t timer = xTimerCreate("timer", pdMS_TO_TICKS(20000), pdFALSE, (void *)0, timer_callback);
    if (timer != NULL) {
        // Start the timer
        xTimerStart(timer, 0);
	while (1) {
		vTaskDelay(pdMS_TO_TICKS(1000));
Users browsing this forum: No registered users and 115 guests
