Favorite IDE for debugging -- Eclipse, Visual Studio, or other?
Hi Everyone,
I have started developing ESP32 code on Windows with Eclipse.
Coming from a visual studio based IDE in the past, I will be trying out VisualGDB next.
(https://visualgdb.com/tutorials/esp32/)
I plan to use a JTAG debugger alot, instead of relying only on printf...
Which IDE do you guys recommend? ...and is there anything other than these two that I should be taking a look at?
EDIT:
The most popular seem to be:
1. eclipse -- free
see official documentation
2. Visual Stduio Community/Pro + VisualGDB -- $$$
3. Visual Studio Code + IDF + OpenOCD -- free
https://gojimmypi.blogspot.com/2017/05/ ... art-1.html
4. Platform IO + Atom (or VSCode) -- free
http://platformio.org/platformio-ide
5. embedXcode for MAC -- Release 7.5.7 adds support for ESP32-DevC
http://embedxcode.weebly.com
EDIT:
1. eclipse -- free
Re: Favorite IDE for debugging -- Eclipse, Visual Studio, or other?
Yeah to start I went with visualgdb too. It makes debugging setup easier.
They aren't always up to date with the new esp-idf, keep that in mind.
Using esp-idf you can integrate with visual studio code or eclipse.
IMO vscode can be set up really well and easily for using esp-idf.
At the moment I don't use JTAG debugging anymore. To me it is more trouble than it's worth.
- ESP_krzychb
- Contact:
Hi @hassan789,Which IDE do you guys recommend?
I have tested Eclipse IDE + GDB Hardware Debugging Plugin and they work great.
Hi @f.h-f.s.At the moment I don't use JTAG debugging anymore. To me it is more trouble than it's worth.
If you could name three key things that make the trouble, what would it be?
Can I name one and only?If you could name three key things that make the trouble, what would it be?
Inability to use JTAG and SDIO/HSPI at the same time due to intersection of pin functions.
I have trouble stepping through code. Somehow the JTAG debugger resets and the next hw-breakpoint does not hit. Overall just a confusing experience (using gdb directly, eclipse pluging and vscode). printline debugging is just way more reliable.krzychb wrote: Hi @f.h-f.s.
- ESP_krzychb
- Contact:
Sure, "killer" issue are welcomeCan I name one and only?
Have you tried latest commit https://github.com/espressif/openocd-es ... 73d7388d11 ?I have trouble stepping through code.
It contains fixes to the stepping.
I might try again =) thanks for the tip.
EDIT
@krzychbI
pulled openocd from espressif, did a build, hooked up my olimex ARM-USB-OCD-H.
Reflashed my LoPy, started OpenOCD.
The program halts on scheduler.
I started monitor, but it keeps resetting O_o
I'm probably doing smthn wrong but idk what =P
EDIT
@krzychbI
running command$ bash -c ${openOCDPath}/src/openocd -s ${openOCDPath}/tcl -f ${openOCDPath}/esp32.cfg
Open On-Chip Debugger 0.10.0-dev-ged7b1a9f-dirty (2017-07-12-10:48)
Licensed under GNU GPL v2
For bug reports, read
adapter speed: 2000 kHz
force hard breakpoints
Info : clock speed 2000 kHz
Info : esp32.cpu0: Debug controller was reset (pwrstat=0xFF, after clear 0xFF).
Info : esp32.cpu0: Core was reset (pwrstat=0xFF, after clear 0xFF).
Info : esp32.cpu0: Debug controller was reset (pwrstat=0xE5, after clear 0x5F).
DELETED
- ESP_krzychb
- Contact:
@f.h-f.s.,pulled openocd from espressif, did a build, hooked up my olimex ARM-USB-OCD-H.
Sorry for missing your post. I am not sure about command to invoke OpenOCD where I see only "-f ${openOCDPath}/esp32.cfg":
With latest commit of OpenOCD, it is run providing separate configuration files (after "-f") for JTAG interface and ESP32 board. For instance for ESP-WROVER-KIT with ESP-WROOM-32 module it looks as follows:
./src/openocd -s ./tcl -f interface/ftdi/esp32_devkitj_v1.cfg -f board/esp-wroom-32.cfg
Ooh, this is a variable defined in vscode's tasks.json
The -s flag adds a directory to search for the tlc directory and I coppied esp32.cfg to my openocd directory
Users browsing this forum: No registered users and 72 guests
