- �[0;33m--- idf_monitor on \\.\COM1 115200 ---�[0m
- --- Quit: Ctrl+] | Menu: Ctrl+T | Help: Ctrl+T followed by Ctrl+H ---
- ����x����������x�x������J╗j% ║%=}9YM� Attempting to open NVS partition
- I (707) MIBAIO_NVS: Flash Opened Successfully
- Guru Meditation Error: Core 0 panic'ed (LoadProhibited). Exception was unhandled.
- Core 0 register dump:
- PC : 0x40001277 PS : 0x00060830 A0 : 0x801830ea A1 : 0x3ffbbb80
- A2 : 0x00000000 A3 : 0x3ffb6d2d A4 : 0x00000000 A5 : 0x00000000
- A6 : 0x00000001 A7 : 0x0000cdcd A8 : 0x8009305b A9 : 0x3ffbbb30
- A10 : 0x3ffc4510 A11 : 0x3ffc4510 A12 : 0x00060820 A13 : 0x00060823
- A14 : 0x00000001 A15 : 0x0000cdcd SAR : 0x00000019 EXCCAUSE: 0x0000001c
- EXCVADDR: 0x00000000 LBEG : 0x4000c349 LEND : 0x4000c36b LCOUNT : 0xffffffff
- Backtrace: 0x40001274:0x3ffbbb80 0x401830e7:0x3ffbbb90 0x401832c2:0x3ffbbbb0 0x40097519:0x3ffbbbe0 0x400d813d:0x3ffbbc30 0x40182aef:0x3ffbbc50 Backtrace: 0x40001274:0x3ffbbb80 0x401830e7:0x3ffbbb90 0x401832c2:0x3ffbbbb0 0x40097519:0x3ffbbbe0 0x400d813d:0x3ffbbc30 0x40182aef:0x3ffbbc50 0x400952e5:0x3ffbbc80
- 0x401830e7: get_uncached_log_level at E:/esp-idf-v5.0.1/components/log/log.c:278
- (inlined by) s_log_level_get_and_unlock at E:/esp-idf-v5.0.1/components/log/log.c:154
- 0x401832c2: esp_log_writev at E:/esp-idf-v5.0.1/components/log/log.c:195
- 0x40097519: esp_log_write at E:/esp-idf-v5.0.1/components/log/log.c:210
- 0x400d813d: app_main at E:/esp-idf-v5.0.1/workspace/MiTask/main/main.c:55 (discriminator 2)
- 0x40182aef: main_task at E:/esp-idf-v5.0.1/components/freertos/FreeRTOS-Kernel/portable/port_common.c:131 (discriminator 2)
- 0x400952e5: vPortTaskWrapper at E:/esp-idf-v5.0.1/components/freertos/FreeRTOS-Kernel/portable/xtensa/port.c:154
- ELF file SHA256: 2bf0f4b9330fea73
- Rebooting...
- ets Jul 29 2019 12:21:46
- rst:0xc (SW_CPU_RESET),boot:0x12 (SPI_FAST_FLASH_BOOT)
- configsip: 0, SPIWP:0xee
- clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
- mode:DIO, clock div:2
- load:0x3fff0030,len:6944
- load:0x40078000,len:15500
- load:0x40080400,len:3844
- 0x40080400: _init at ??:?
- entry 0x4008064c
- I (27) boot: ESP-IDF v5.0.1-dirty 2nd stage bootloader
- I (27) boot: compile time 13:13:43
- I (27) boot: chip revision: v3.0
- I (31) boot.esp32: SPI Speed : 40MHz
- I (35) boot.esp32: SPI Mode : DIO
- I (40) boot.esp32: SPI Flash Size : 8MB
- I (45) boot: Enabling RNG early entropy source...
- I (50) boot: Partition Table:
- I (53) boot: ## Label Usage Type ST Offset Length
- I (61) boot: 0 nvs WiFi data 01 02 00009000 00006000
- I (68) boot: 1 phy_init RF data 01 01 0000f000 00001000
- I (76) boot: 2 factory factory app 00 00 00010000 00177000
- I (83) boot: End of partition table
- I (87) esp_image: segment 0: paddr=00010020 vaddr=3f400020 size=265c4h (157124) map
- I (153) esp_image: segment 1: paddr=000365ec vaddr=3ffbdb60 size=06744h ( 26436) load
- I (163) esp_image: segment 2: paddr=0003cd38 vaddr=40080000 size=032e0h ( 13024) load
- I (169) esp_image: segment 3: paddr=00040020 vaddr=400d0020 size=b47d8h (739288) map
- I (436) esp_image: segment 4: paddr=000f4800 vaddr=400832e0 size=1b658h (112216) load
- I (498) boot: Loaded app from partition at offset 0x10000
- I (498) boot: Disabling RNG early entropy source...
- I (510) cpu_start: Pro cpu up.
- I (510) cpu_start: Starting app cpu, entry point is 0x4008143c
- 0x4008143c: call_start_cpu1 at E:/esp-idf-v5.0.1/components/esp_system/port/cpu_start.c:142
- I (497) cpu_start: App cpu up.
- I (526) cpu_start: Pro cpu start user code
- I (526) cpu_start: cpu freq: 160000000 Hz
- I (526) cpu_start: Application information:
- I (531) cpu_start: Project name: app-template
- I (537) cpu_start: App version: v5.0.1-dirty
- I (542) cpu_start: Compile time: Apr 12 2023 13:12:56
- I (548) cpu_start: ELF file SHA256: 2bf0f4b9330fea73...
- I (554) cpu_start: ESP-IDF: v5.0.1-dirty
- I (559) cpu_start: Min chip rev: v0.0
- I (564) cpu_start: Max chip rev: v3.99
- I (569) cpu_start: Chip rev: v3.0
- I (574) heap_init: Initializing. RAM available for dynamic allocation:
- I (581) heap_init: At 3FFAFF10 len 000000F0 (0 KiB): DRAM
- I (587) heap_init: At 3FFB6388 len 00001C78 (7 KiB): DRAM
- I (593) heap_init: At 3FFB9A20 len 00004108 (16 KiB): DRAM
- I (599) heap_init: At 3FFCB698 len 00014968 (82 KiB): DRAM
- I (605) heap_init: At 3FFE0440 len 00003AE0 (14 KiB): D/IRAM
- I (612) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM
- I (618) heap_init: At 4009E938 len 000016C8 (5 KiB): IRAM
- I (626) spi_flash: detected chip: generic
- I (629) spi_flash: flash io: dio
- W (633) spi_flash: Detected size(16384k) larger than the size in the binary image header(8192k). Using the size in the binary image header.
- I (647) cpu_start: Starting scheduler on PRO CPU.
- I (0) cpu_start: Starting scheduler on APP CPU.
- I (657) MIBAIO_NVS: Checking NVS Flash
- I (707) MIBAIO_NVS: Attempting to open NVS partition
- Backtrace: 0x40001274:0x3ffbbb80 0x401830e7:0x3ffbbb90 0x401832c2:0x3ffbbbb0 0x40097519:0x3ffbbbe0 0x400d813d:0x3ffbbc30 0x40182aef:0x3ffbbc50 0x400952e5:0x3ffbbc80
- Rebooting...
- entry 0x4008064c
- Rebooting...
- entry 0x4008064c
- Rebooting...
- entry 0x4008064c
- Rebooting...
Rebooting Esp32 during running after return statement
Re: Rebooting Esp32 during running after return statement
Because of:
It would be less unwieldy if you shorten the log to only contain a single reboot cycle. Also, it's hard for us to guess at your problem, it would be easier to help if you describe your problem.
it looks like you are referencing a NULL pointer. Maybe tell us what's at: lineEXCVADDR: 0x00000000
(from the stack trace) or possibly post the whole main function.main.c:55
My guess: ESP_LOGI( NULL, ... )Maybe tell us what's at: line
main.c:55
Users browsing this forum: MSN [Bot], odelot and 74 guests
