I created a test case for this scan response problem with ESP32 V3. Code is here https://github.com/zapta/esp32_scan_resp and it contains 1) A simple platformio esp32 project that implements a BLE advertiser and 2) A python program that scans and prints ble devices it find.
With ESP32-V1 everything works well and the scanner does find the device. With ESP32-V3, the scan response is broken to a point that the scanner doesn't detects and prints the device name.
I would appreciate if anybody can reproduce using this repository. You will need VSCode with the platformio extension and a python interpreter.
Edit: filed this bug report https://github.com/espressif/esp-idf/issues/10660
Bluetooth BLE does not work with ESP32-D0WD-V3 chip
Re: Bluetooth BLE does not work with ESP32-D0WD-V3 chip
I had contact to espressif. They could not believe the issue.
I sent they two pieces of DEV-Kits.
Was there any update on this topic please?
Users browsing this forum: Bing [Bot], Google [Bot] and 73 guests
