File upload using socket succeeds but not with esp_http_client
Re: File upload using socket succeeds but not with esp_http_client
Hi. I was trying to upload file but my server on clojure (ring.adapter.jetty) determines a error. I pointed on array with data in function esp_http_client_set_post_field(...)
Hi @amehta,
it would be perfect to see your solution as I am struggling to get it to work.
best regards and thanks in advance!!
eofeof
eofeof
I would be interested in you solution as well amehta.amehta wrote: yes I have completed the file upload function. Let me know if you need help.
Could you share it? Would be really nice!!
@ahmehta I am trying to do the exact same thing. Please let me know what fixed your error. Also, did you need to initialize a handler function for the esp_http_client object? I am new to esp32 so I am still learning.
Thanks in advance!
Thanks in advance!
Hello everyone!
I'm also trying to send large file from LittleFS to server using esp_http_client. Server responds the 400 error code, and "No file part". Server code works, tested with Postman
The code for sending using esp_http_client:
The server code:
esp_err_t upload_file_to_server(string fname, string basename, int file_size) {
ESP_LOGI(TAG, "Sending %s with size %d", basename.c_str(), file_size);
esp_err_t err = ESP_OK;
int status_code = 0;
int content_length = 0;
int total_read_len = 0, read_len = 0;
int total_len_to_send = 0;
char tmp_buf[256];
char BODY[512];
char END[128];
memset(BODY, 0, sizeof(BODY));
memset(END, 0, sizeof(END));
memset(tmp_buf, 0, sizeof(tmp_buf));
FILE * f = fopen(fname.c_str(), "rb");
if (!f) {
ESP_LOGE(TAG, "Cannot open file to upload!");
return ESP_FAIL;
uint8_t * send_buffer = (uint8_t*)malloc(MAX_HTTP_OUTPUT_BUFFER*sizeof(uint8_t));
if (!send_buffer) {
ESP_LOGE(TAG, "Cannot allocate mem for temp buffer!");
err = ESP_ERR_NO_MEM;
goto file_upload_buffer_allocate_failed;
bzero(send_buffer, MAX_HTTP_OUTPUT_BUFFER);
esp_http_client_set_method(wav_sender_client, HTTP_METHOD_POST);
sprintf(tmp_buf, "multipart/form-data; boundary=%s", WAV_FILE_BOUNDARY);
esp_http_client_set_header(wav_sender_client, "Content-Type", tmp_buf);
sprintf(tmp_buf, "%d", file_size);
esp_http_client_set_header(wav_sender_client, "Content-Length", tmp_buf);
// memset(tmp_buf, 0, sizeof(tmp_buf));
// sprintf(tmp_buf, "attachment; name=\"file\"; filename=\"%s\"", basename.c_str());
// esp_http_client_set_header(wav_sender_client, "Content-Disposition", tmp_buf);
esp_http_client_set_header(wav_sender_client, "Accept", "*/*");
sprintf(tmp_buf, "--%s\r\n", WAV_FILE_BOUNDARY);
strcpy(BODY, tmp_buf);
sprintf(tmp_buf, "Content-Disposition: form-data; name=\"file\"; filename=\"%s\"\r\n", basename.c_str());
strcat(BODY, tmp_buf);
sprintf(tmp_buf, "Content-Type: application/octet-stream\r\n\r\n");
sprintf(tmp_buf, "\r\n%s--\r\n\r\n", WAV_FILE_BOUNDARY);
strcpy(END, tmp_buf);
total_len_to_send = file_size+strlen(BODY)+strlen(END);
sprintf(tmp_buf, "%d", total_len_to_send);
printf("%s", BODY);
printf("%s", END);
if ((err = esp_http_client_open(wav_sender_client, total_len_to_send)) != ESP_OK) {
ESP_LOGE(TAG, "Failed to open HTTP connection: %s", esp_err_to_name(err));
goto file_upload_connection_failed;
ESP_LOGI(TAG, "Connection opened");
// vTaskDelay(pdMS_TO_TICKS(100));
if (esp_http_client_write(wav_sender_client, BODY, sizeof(BODY)) == ESP_FAIL) {
ESP_LOGE(TAG, "Cannot send BODY preamble");
goto file_upload_connection_end;
while (fread(&send_buffer[0], sizeof(uint8_t), MAX_HTTP_OUTPUT_BUFFER, f) > 0) {
int snt = esp_http_client_write(wav_sender_client, (char*)send_buffer, MAX_HTTP_OUTPUT_BUFFER);
if (snt == ESP_FAIL) {
ESP_LOGE(TAG, "Cannot send part");
if (esp_http_client_write(wav_sender_client, END, sizeof(END)) == ESP_FAIL) {
ESP_LOGE(TAG, "Cannot send END preamble");
content_length = esp_http_client_fetch_headers(wav_sender_client);
total_read_len = 0;
if (total_read_len < content_length && content_length <= MAX_HTTP_OUTPUT_BUFFER) {
read_len = esp_http_client_read(wav_sender_client, (char*)send_buffer, content_length);
if (read_len <= 0) {
ESP_LOGE(TAG, "Error read data");
err = ESP_FAIL;
send_buffer[read_len] = 0;
ESP_LOGI(TAG, "read_len = %d", read_len);
status_code = esp_http_client_get_status_code(wav_sender_client);
ESP_LOGI(TAG, "HTTP Status = %d, content_length = %d",
status_code,
esp_http_client_get_content_length(wav_sender_client));
if (status_code >= 400) {
ESP_LOGE(TAG, "Error sending file!");
err = ESP_FAIL;
file_upload_connection_end:
esp_http_client_close(wav_sender_client);
ESP_LOGI(TAG, "Connection closed");
file_upload_connection_failed:
esp_http_client_delete_header(wav_sender_client, "Content-Type");
esp_http_client_delete_header(wav_sender_client, "Content-Length");
esp_http_client_delete_header(wav_sender_client, "Content-Disposition");
esp_http_client_delete_header(wav_sender_client, "Accept");
free(send_buffer);
file_upload_buffer_allocate_failed:
fclose(f);
return err;
@app.route('/upload-record', methods=['POST'])
def upload_record():
# check if the post request has the file part
if 'file' not in request.files:
print("No file part")
return make_response('No file part', 400)
file = request.files['file']
# if user does not select file, browser also
# submit an empty part without filename
if file.filename == '':
print("No selected file")
return make_response('No selected file', 400)
if file and allowed_file(file.filename):
filename = secure_filename(file.filename)
file.save(os.path.join(app.config['UPLOAD_FOLDER'], filename))
return "Record uploaded!"
else:
return make_response('Wrong file or its format', 400)
Users browsing this forum: No registered users and 318 guests
