Hi
I am trying to push some data to sever by http over wifi, but after sending 30-40 minutes it showing the error "wifi: bcn_timout,ap_probe_send_start " , Wifi is disconnecting and trying to connect again, it will connect and show the same error and disconnect. Please help me fix this issue. Please find attachment for error details.
Wifi is getting reset after running continuously showing an error "wifi: bcn_timout,ap_probe_send_start "
- wifi_code.c
- (3.79 KiB) Downloaded 568 times
- wifi_issue_new.png (43.89 KiB) Viewed 5695 times
Re: Wifi is getting reset after running continuously showing an error "wifi: bcn_timout,ap_probe_send_start "
I think what happened here is: wifi beacon frame was sent, this timed out. the esp32 tried to probe the AP, this also failed, which is why you were disconnected
You can expand your event_handler to reconnect if wifi disconnects, also you can move the connect call to the event handler:
You can also use a event group to set bits, which is recommended by freertos.
instead of wifi_connect and check_one_time
static esp_err_t event_handler(void *ctx, system_event_t *event)
switch (event->event_id)
case SYSTEM_EVENT_STA_START:
esp_wifi_connect();
break;
case SYSTEM_EVENT_STA_GOT_IP:
ESP_LOGI(TAG, "ip: %d.%d.%d.%d", IP2STR(&event->event_info.got_ip.ip_info.ip));
break;
case SYSTEM_EVENT_STA_DISCONNECTED:
esp_wifi_connect();
ESP_LOGE(TAG, "Wifi Disconnected!");
break;
default:
break;
return ESP_OK;
xEventGroupSetBits(wifi_event_group, CONNECTED_BIT);
Thanks for the replay sir
I tried the way as you said, changed the event_handler .But still the same issue coming " wifi: bcn_timout,ap_probe_send_start". Please tell any other suggestion you know to fix it.
Users browsing this forum: No registered users and 102 guests
