Using Arduino with ESP32 MINI (newbie)
leotordo
Postby leotordo » Thu Feb 02, 2023 2:02 pm
Hello everybody.
Sorry but I'm newbie in ESP32 World.
I developed a simple application with ESP-WROOM-32 Dev Kit Board (like AZ Delivery board for example).
I connected USB cable and with IDE I wrote my code.
Now I want to use ESP32­C3­MINI­1 module
https://www.espressif.com/sites/default ... eet_en.pdf
I've some questions
  • Is the virgin EPS32C3MINI1 that I buy on Digikey (for example) ready to be connected to Arduino IDE via UART or needs to be programmed first?
  • On ESP32CMINI1 application schematic I see external oscillator. Is there an internal oscillator? I've not to much space on my board
Thank you all
Stefano
ESP_Minatel
Re: Using Arduino with ESP32 MINI (newbie)
Postby ESP_Minatel » Thu Feb 02, 2023 5:15 pm
You can flash an unprogrammed ESP32-C3 using Arduino IDE.
If you talking about pins 12 and 13 on the MINI1 module, these pins are the low-frequency crystal (32kHz). Internally on the module, you will find only the high-frequency crystal (40MHz).
leotordo
Postby leotordo » Fri Feb 03, 2023 3:06 pm
Thank you very much :-)
Stefano
Users browsing this forum: No registered users and 73 guests
