Exception output over USB with ESP32 S3?
aaronw
Postby aaronw » Mon Oct 17, 2022 8:14 pm
Related to my previous open question about the ee.vld.128.ip instruction failing viewtopic.php?f=2&t=30121 instruction failing, how do I get the ESP32 S3 to dump out exception information over the USB interface? On the project I'm working on I would much prefer to not have to have a UART interface as well as USB due to size constraints. Is there a way to have exception information printed out the USB interface either instead of or along with the UART interface?
ESP_igrr
Re: Exception output over USB with ESP32 S3?
Postby ESP_igrr » Mon Oct 17, 2022 9:26 pm
The answer might depend on whether you are using IDF or Arduino.
In IDF, console output and panic handler messages are printed both to UART and USB_SERIAL_JTAG by default. You can change this in menuconfig if desired.
In Arduino the default Serial destination it is configured by one of the options in Tools menu.
aaronw
Postby aaronw » Wed Oct 19, 2022 9:25 am
In my case, I am using the Arduino environment. There does not appear to be any setting that controls this there. I can see other print statements without any issues, only the exception information only appears to go to the UART interface.
nickolay
Postby nickolay » Sun Dec 31, 2023 2:45 am
I was using an old version of ESP32 Arduino without realizing it. This manifested in missing backtrace info — Serial output and task watchdog messages displayed fine over USB-CDC.
Newer versions (esp32-arduino 2.0.7+ / esp-idf 4.4.4) print to USB serial by default (assuming you see any output at all). I tested with this sketch:
void setup()
  Serial.begin(115200);
  Serial.println("Let's provoke the s/w wdt firing...");
  sleep(5);
  int *x = 0;
  *x = 5;
  Serial.println("This line will not ever print out");
void loop(){}
For the reference, the panic handler code is here, and esp32-arduino wraps it, but doesn't override.
Guru Meditation Error: Core  0 panic'ed (StoreProhibited). Exception was unhandled.
Core  0 register dump:
PC      : 0x42002a73  PS      : 0x00060830  A0      : 0x82003fa5  A1      : 0x3fcebd70
A2      : 0x00000000  A3      : 0x00000000  A4      : 0x00000000  A5      : 0x00000000
A6      : 0x3fcebf04  A7      : 0x80000001  A8      : 0x82002a70  A9      : 0x3fcebd50
A10     : 0x00000000  A11     : 0x00000004  A12     : 0x0007ffff  A13     : 0x80000000
A14     : 0x02c93da0  A15     : 0x00ffffff  SAR     : 0x00000010  EXCCAUSE: 0x0000001d
EXCVADDR: 0x00000000  LBEG    : 0x40056f5c  LEND    : 0x40056f72  LCOUNT  : 0xffffffff
Users browsing this forum: Google [Bot], YaCy [Bot] and 100 guests
