I need to encrypt comunication from an ESP32 to a MQTTs server, I have done several time with the class WifiClientSecure over Wifi and also over Ethernet with the boards of Olimex ESP32-EVB and also ESP32 Poe that use the LAN8720, but like this boards are having EMIs issues with the network interface at least in my cases, I have tried with Adafruit Ethernet Feather ESP32 and the FeatherWings. Wiht this board I don`t have EMI issues but I cannot connect to the MQTTs server using WifiClientSecure over Ethernet like in the case of Olimex boards.
Olimex boards use the library ETH.h and the Adafruit use the library Ethernet2.h
If someone can help me a little would be very apreciated.
Thanks!
Re: WifiClientSecure over Ethernet
What library do you replace WiFiClientSecure with when using the Olimex boards?
This code works with a Wiz850io and the ESP32 using MQTT (non-TLS)
Other option might be.....http://wizwiki.net/wiki/doku.php?id=ewb ... t_shield_s
#include <PubSubClient.h>
#include <SPI.h>
#include <Ethernet2.h>
#include <EthernetUdp2.h>
#include "time.h"
const char* ssid = "xxxxxxxxx";
const char* password = "xxxxxxxxxxx";
const char* mqttServer = "xxxxxxxxxx";
const int mqttPort = 1883;
const char* mqttUser = "xxxxxx";
const char* mqttPassword = "xxxxxxxxxx";
uint8_t baseMac[6];
unsigned int localPort = 8888; // local port to listen for UDP packets
char timeServer[] = "time.nist.gov"; // time.nist.gov NTP server
const int NTP_PACKET_SIZE = 48; // NTP time stamp is in the first 48 bytes of the message
byte packetBuffer[ NTP_PACKET_SIZE]; //buffer to hold incoming and outgoing packets
// A UDP instance to let us send and receive packets over UDP
EthernetUDP Udp;
//const int timeZone = -6; // Central Standard Time
const int timeZone = 5; // Central Daylight Time
//const int timeZone = -5; // Eastern Standard Time (USA)
//const int timeZone = -4; // Eastern Daylight Time (USA)
//const int timeZone = -8; // Pacific Standard Time (USA)
//const int timeZone = -7; // Pacific Daylight Time (USA)
#if defined(ESP8266)
// default for ESPressif
#define WIZ_CS 15
#elif defined(ESP32)
#define WIZ_CS 4
#elif defined(ARDUINO_STM32_FEATHER)
// default for WICED
#define WIZ_CS PB4
#elif defined(TEENSYDUINO)
#define WIZ_CS 10
#elif defined(ARDUINO_FEATHER52)
#define WIZ_CS 11
#else // default for 328p, 32u4 and m0
#define WIZ_CS 10
#endif
float rain = 0.00;
String rainStr = "";
float tempT = 35.0;
String tempTStr = "";
byte rainDir = 1;
byte tempTDir = 1;
unsigned long timePub = 0UL;
unsigned long updateNTP = 30000UL;
unsigned long currentTime = 0UL;
EthernetClient espClient;
PubSubClient client(espClient);
esp_read_mac(baseMac, ESP_MAC_WIFI_STA);
delay(500);
Serial.print(F("Mac Address: "));
for (byte x = 0; x < 6; x++)
if (baseMac[x] < 0x10)
Serial.print(F("0"));
Serial.print(baseMac[x]);
else
Serial.print(baseMac[x], HEX);
if (x < 5)
Serial.print(F(":"));
Serial.println(F(""));
Ethernet.init(WIZ_CS);
delay(1000);
if (Ethernet.begin(baseMac) == 0) {
// no point in carrying on, so do nothing forevermore:
while (1) {
Serial.println("Failed to configure Ethernet using DHCP");
delay(10000);
Serial.print(F("IP number assigned by DHCP is "));
Serial.println(Ethernet.localIP());
Udp.begin(localPort);
delay(1000);
getTime();
currentTime = millis();
client.setServer(mqttServer, mqttPort);
client.setCallback(callback);
while (!client.connected()) {
Serial.println("Connecting to MQTT...");
if (client.connect("ESP32Client", mqttUser, mqttPassword )) {
Serial.println("connected");
Serial.print("failed with state ");
Serial.print(client.state());
delay(2000);
client.publish("your pub topic", "Test MQTT Client Starting");
client.subscribe("your sub topic 1");
client.subscribe("your sub topic 2");
timePub = millis();
rainStr = String(rain, 2);
tempTStr = String(tempT, 1);
void callback(char* topic, byte* payload, unsigned int length) {
Serial.print("Message arrived in topic: ");
Serial.println(topic);
Serial.print("Message:");
for (int i = 0; i < length; i++) {
Serial.print((char)payload[i]);
Serial.println();
Serial.println("-----------------------");
time_t prevDisplay = 0; // when the digital clock was displayed
client.loop();
if (millis() < currentTime)
if (millis() - currentTime > updateNTP)
getTime();
if (millis() < timePub)//account for millis() rollover
timePub = millis() - timePub;
if ((millis() - timePub) > 60000UL)
if (rainDir == 0)
rain -= 0.01;
else
rain += 0.01;
if (rain >= 5.00)
rainDir = 0;
if (rain <= 0.00)
rainDir = 1;
if (tempTDir == 0)
tempT -= 0.1;
else
tempT += 0.1;
if (tempT >= 40.0)
tempTDir = 0;
if (tempT <= 32.0)
tempTDir = 1;
String pubString = String(rainStr + "," + tempTStr);
char message_buff[pubString.length() + 1];
pubString.toCharArray(message_buff, pubString.length() + 1);
client.publish("robe/test", message_buff);
timePub = millis();
//-------- NTP code ----------
// send an NTP request to the time server at the given address
void sendNTPpacket(const char * address) {
// set all bytes in the buffer to 0
memset(packetBuffer, 0, NTP_PACKET_SIZE);
// Initialize values needed to form NTP request
// (see URL above for details on the packets)
packetBuffer[0] = 0b11100011; // LI, Version, Mode
packetBuffer[1] = 0; // Stratum, or type of clock
packetBuffer[2] = 6; // Polling Interval
packetBuffer[3] = 0xEC; // Peer Clock Precision
// 8 bytes of zero for Root Delay & Root Dispersion
packetBuffer[12] = 49;
packetBuffer[13] = 0x4E;
packetBuffer[14] = 49;
packetBuffer[15] = 52;
// all NTP fields have been given values, now
// you can send a packet requesting a timestamp:
Udp.beginPacket(address, 123); //NTP requests are to port 123
Udp.write(packetBuffer, NTP_PACKET_SIZE);
Udp.endPacket();
void getTime()
sendNTPpacket(timeServer); // send an NTP packet to a time server
// wait to see if a reply is available
delay(1000);
if ( Udp.parsePacket() ) {
// We've received a packet, read the data from it
Udp.read(packetBuffer, NTP_PACKET_SIZE); // read the packet into the buffer
//the timestamp starts at byte 40 of the received packet and is four bytes,
// or two words, long. First, esxtract the two words:
unsigned long highWord = word(packetBuffer[40], packetBuffer[41]);
unsigned long lowWord = word(packetBuffer[42], packetBuffer[43]);
// combine the four bytes (two words) into a long integer
// this is NTP time (seconds since Jan 1 1900):
unsigned long secsSince1900 = highWord << 16 | lowWord;
Serial.print("Seconds since Jan 1 1900 = " );
Serial.println(secsSince1900);
// now convert NTP time into everyday time:
Serial.print("Unix time = ");
// Unix time starts on Jan 1 1970. In seconds, that's 2208988800:
const unsigned long seventyYears = 2208988800UL;
// subtract seventy years:
unsigned long epoch = secsSince1900 - seventyYears;
// print Unix time:
Serial.println(epoch);
// print the hour, minute and second:
Serial.print("The UTC time is "); // UTC is the time at Greenwich Meridian (GMT)
Serial.print((epoch % 86400L) / 3600); // print the hour (86400 equals secs per day)
Serial.print(':');
if ( ((epoch % 3600) / 60) < 10 ) {
// In the first 10 minutes of each hour, we'll want a leading '0'
Serial.print('0');
Serial.print((epoch % 3600) / 60); // print the minute (3600 equals secs per minute)
Serial.print(':');
if ( (epoch % 60) < 10 ) {
// In the first 10 seconds of each minute, we'll want a leading '0'
Serial.print('0');
Serial.println(epoch % 60); // print the second
Users browsing this forum: No registered users and 35 guests
