esp32 dev board not connecting to wifi
Posted: Mon Aug 27, 2018 1:43 pm
i have an issue with my esp32 development board not connecting to wifi it just says connecting on the serial monnitor but never connects all the login details are correct.
the code has been hashed together from several sources however but was working
#include <Adafruit_Sensor.h>
//#include "DHT.h"
#include <WiFi.h>
#include <PubSubClient.h>
#include "SparkFunHTU21D.h"
//Create an instance of the object
HTU21D myHumidity;
const char* ssid = "skynet";
const char* password = "Sexyfrog9919";
const char* mqttServer = "192.168.0.196";
const int mqttPort = 1883;
const char* mqttUser = "ojosbourne";
const char* mqttPassword = "Skingsking9919";
#define temperature_topic "topic/temp" //Topic temperature
#define humidity_topic "topic/humid" //Topic humidity
//#define debug_topic "debug" //Topic for debugging
//here we use pin IO23 of ESP32 to read data
//#define DHTPIN 14
//our sensor is DHT22 type
//#define DHTTYPE DHT22
//create an instance of DHT sensor
//DHT dht(DHTPIN, DHTTYPE);
WiFiClient espClient;
PubSubClient client(espClient);
void setup() {
//void setup() (
// connect to wifi
Serial.begin(115200);
WiFi.begin(ssid, password);
delay(200);
Serial.println("Connecting to WiFi..");
Serial.println("Connected to the WiFi network");
// connect to mqtt
client.setServer(mqttServer, mqttPort);
while (!client.connected()) {
Serial.println("Connecting to MQTT...");
if (client.connect("ESP32Client", mqttUser, mqttPassword )) {
Serial.println("connected");
} else {
Serial.print("failed with state ");
Serial.print(client.state());
delay(200);
//Serial.begin(115200);
//Serial.println("DHT22 sensor!");
//call begin to start sensor
//dht.begin();
Serial.println("HTU21D Example!");
myHumidity.begin();
void loop() {
float h = myHumidity.readHumidity();
float t = myHumidity.readTemperature();
//use the functions which are supplied by library.
//float h = dht.readHumidity();
// Read temperature as Celsius (the default)
//float t = dht.readTemperature();
// Check if any reads failed and exit early (to try again).
if (isnan(h) || isnan(t)) {
Serial.println("Failed to read from htu21d sensor!");
return;
// print the result to Terminal
//client.publish(humidity_topic, (h));
Serial.print("Humidity: ");
Serial.print(h);
Serial.print(" %\t");
// client.publish(temperature_topic, (t));
Serial.print("Temperature: ");
Serial.print(t);
Serial.println(" *C ");
// Publish values to MQTT topics
client.publish(temperature_topic, String(t).c_str(), true); // Publish temperature on mosohomes/temp1
//if ( debug ) {
Serial.println("Temperature sent to MQTT.");
delay(200); //some delay is needed for the mqtt server to accept the message
client.publish(humidity_topic, String(h).c_str(), true); // Publish humidity on mosohomes/humid1
//if ( debug ) {
Serial.println("Humidity sent to MQTT.");
//we delay a little bit for next read
delay(10000);
