ESP Call Back / Interrupt Issue
Posted: Sun Jul 01, 2018 10:51 pm
Hey guys
Before anyone asks "Yes i have searched for a fix" unfortunately I'm quite new to C++/Arduino and a fair few of the details in the other posts confuse me.
so my issue is, i have an ESP32 (TTGO Lora32) I'm using the default SPI for the lora and the flash. I've disabled the on-board display and i have reconfigured the "Hardware Serial(1)" to use pins 34 and 35 for a neo 6m receiver and i have MPU9250 on i2c bus pins 21 and 13. the device is taking position and mpu readings and sending them out to a lora mesh and also over BT to an android app. The GPS and the MPU9250 reads/workload where associated with core1 task and the lora and other work happened on core0. (when i started having issues i moved all the code back to core0)
In my first attempt i had no software interrupts or callbacks and the device would run indefinitely. However recently we went through an optimization and placed a lora receive callback in the code. then it randomly started doing this:
Guru Meditation Error: Core 1 panic'ed (Interrupt wdt timeout on CPU1)
Core 1 register dump:
PC : 0x4008c9e6 PS : 0x00060634 A0 : 0x8008bba6 A1 : 0x3ffc0a70
A2 : 0x3ffcd28c A3 : 0x3ffd2698 A4 : 0x00060621 A5 : 0x00000001
A6 : 0x00060621 A7 : 0x00060523 A8 : 0x3ffd2698 A9 : 0x3ffd2698
A10 : 0x00000018 A11 : 0x00000018 A12 : 0x00000000 A13 : 0x00000001
A14 : 0x00060623 A15 : 0x00000000 SAR : 0x00000010 EXCCAUSE: 0x00000006
EXCVADDR: 0x00000000 LBEG : 0x4000142d LEND : 0x4000143a LCOUNT : 0xfffffffd
Core 1 was running in ISR context:
EPC1 : 0x4008b263 EPC2 : 0x00000000 EPC3 : 0x00000000 EPC4 : 0x4008c9e6
Backtrace: 0x4008c9e6:0x3ffc0a70 0x4008bba3:0x3ffc0a90 0x4008a9bf:0x3ffc0ab0 0x400d677d:0x3ffc0af0 0x400d6bdd:0x3ffc0b10 0x40178331:0x3ffc0b30 0x400d6d76:0x3ffc0b50 0x400d3426:0x3ffc0b70 0x400d3a68:0x3ffc0bb0 0x400d3a7e:0x3ffc0bd0 0x40080ead:0x3ffc0bf0 0x400816cd:0x3ffc0c10 0x400d679d:0x00000000
Core 0 register dump:
PC : 0x4008b280 PS : 0x00060034 A0 : 0x8008b88b A1 : 0x3ffc05a0
A2 : 0x3ffc1170 A3 : 0x00000000 A4 : 0x00000005 A5 : 0x00000020
A6 : 0x00000020 A7 : 0x00000001 A8 : 0x0000abab A9 : 0x0000cdcd
A10 : 0xb33fffff A11 : 0x0000abab A12 : 0x00060021 A13 : 0x00000001
A14 : 0x00060021 A15 : 0x00060923 SAR : 0x0000001a EXCCAUSE: 0x00000006
EXCVADDR: 0x00000000 LBEG : 0x00000000 LEND : 0x00000000 LCOUNT : 0x00000000
Backtrace: 0x4008b280:0x3ffc05a0 0x4008b888:0x3ffc05c0 0x4008c747:0x3ffc05e0 0x4008c461:0x3ffc0600 0x400816d6:0x3ffc0610 0x401537ef:0x00000000
I have tried to install the ESP8266/ESP32 exception debugger in the Ard IDE but its not working
i beleive it is the callback causing the crash as the code has all been copied over from the original sketch's, the only fundamental difference is the call back:LoRa.onReceive(onReceive); instead of reading every time the device cycles. like in the example given with the lora send / receive examples.
Is it possible that the call back is being called multiple times, should i be taking the device out of receive mode when responding to the call back so it doesnt call again perhaps ?
Also if anyone knows of any boards with this type of configuration please feel free to suggest, i dont want to have to have this manufactured if i can help it
