ESP32-S3 (N32R8) boots only from ota_0 after successful OTA update – PlatformIO/Arduino
Posted: Sat Jan 18, 2025 9:39 pm
I'm working on an ESP32-S3-WROOM-2-N32R8 (32MB Flash, 8MB PSRAM) project using PlatformIO in VSCode with the Arduino framework. My goal is to implement OTA updates, but I'm running into an issue: The ESP32 always boots from ota_0 (partition app0), even though the OTA update to ota_1 (partition app1) completes successfully without any errors.
Problem Details:
OTA update writes the new firmware to ota_1 and marks it as the boot partition successfully.
Calls to esp_ota_get_boot_partition() confirm that the boot partition has been updated to ota_1 post-update.
On reboot, the ESP32 always boots from ota_0 (instead of ota_1 as intended)
Environment:
Board: ESP32-S3-WROOM-2-N32R8V (32MB Flash, 8MB PSRAM Octal)
Platform: PlatformIO (VSCode)
Framework: Arduino
Partition Table:
Analysis conducted
The following analysis has been conducted:
1. Find the current boot partition (before update)
Result: Current boot partition: app0
2. Check if ota partition is bootable
Result: Partition is bootable.
3. Checked the ota partition's address
Result: The partition, which the new firmware is written to, shows address 0xBC0000 (app1) correctly.
4. Verified result on setting boot partition
Result: ESP_OK = Boot partition set to app1 without error
5. Forced the ota partition to mark app as valid after verification.
Result: Partition is valid. / App marked as valid.
6. Read-out the contents of ota_data partition
The following data is stored in the otadata partition (address: 0xE000, length 0x2000)
Result: This indicates that the boot loader has correctly been set to app1 as boot partition.
Question
How come that my ESP32 is still booting from partition app0 after reboot / power cycle?
The serial output confirms:
Address 0x10000 is app0, not as after ota update confirmed address 0xBC0000.
Thanks a lot for your help!
Problem Details:
Environment:
Framework: Arduino
Partition Table:
# Name, Type, SubType, Offset, Size, Flags
nvs, data, nvs, 0x9000, 0x5000,
otadata, data, ota, 0xE000, 0x2000,
app0, app, ota_0, 0x10000, 0xBB0000,
app1, app, ota_1, 0xBC0000, 0xBB0000,
nvm, data, nvs, 0x1770000, 0x890000,
if (_partitionIsBootable(_partition) == true) {
Serial.println("[Updater] Partition is bootable.");
Serial.println("[Updater] New partition address: " + String(_partition->address));
esp_err_t result = esp_ota_set_boot_partition(_partition);
if (esp_partition_verify(_partition)) {
// Mark the newly flashed partition as valid, if partition is valid
esp_err_t err = esp_ota_mark_app_valid_cancel_rollback();
if (err != ESP_OK) {
Serial.println("[Updater] Error: Partition not valid.");
Serial.println("[Updater] Error marking app valid! Code: " + String(err));
} else {
Serial.println("[Updater] Partition is valid.");
Serial.println("[Updater] App marked as valid. OK! Code: " + String(err));
01 00 00 00 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 9A 98 43 47
Question
Currently running from partition: Type: 0, Subtype: 16, Address: 0x10000
