void print_shit(void)
char *str = (char *)malloc(sizeof(char) * 2000);
memset(str, 0, 2000);
char *pcWriteBuffer = str;
TaskStatus_t *pxTaskStatusArray;
volatile UBaseType_t uxArraySize, x;
unsigned long ulStatsAsPercentage;
uint32_t ulTotalRunTime;
/* Make sure the write buffer does not contain a string. */
*pcWriteBuffer = 0x00;
/* Take a snapshot of the number of tasks in case it changes while this
function is executing. */
uxArraySize = uxTaskGetNumberOfTasks();
/* Allocate a TaskStatus_t structure for each task. An array could be
allocated statically at compile time. */
Serial.printf("sizeof TaskStatus_t: %d\n", sizeof(TaskStatus_t));
pxTaskStatusArray = (TaskStatus_t*)pvPortMalloc( uxArraySize * sizeof(TaskStatus_t));
memset(pxTaskStatusArray, 0, uxArraySize * sizeof(TaskStatus_t));
if( pxTaskStatusArray != NULL )
/* Generate raw status information about each task. */
Serial.printf("Array size before: %d\n", uxArraySize);
uxArraySize = uxTaskGetSystemState( pxTaskStatusArray,
uxArraySize,
&ulTotalRunTime );
Serial.printf("Array size after: %d\n", uxArraySize);
Serial.printf("Total runtime: %d\n", ulTotalRunTime);
/* For percentage calculations. */
ulTotalRunTime /= 100UL;
/* Avoid divide by zero errors. */
if( ulTotalRunTime > 0 )
/* For each populated position in the pxTaskStatusArray array,
format the raw data as human readable ASCII data. */
Serial.printf(" name runtime pct core prio\n");
for( int x = 0; x < uxArraySize; x++ )
TaskStatus_t *fuckit;
void *tmp = &pxTaskStatusArray[x];
void *hmm = tmp + (4 * x);
fuckit = (TaskStatus_t*)hmm;
// Serial.printf("Name: %.5s, ulRunTimeCounter: %d\n", fuckit->pcTaskName , fuckit->ulRunTimeCounter);
/* What percentage of the total run time has the task used?
This will always be rounded down to the nearest integer.
ulTotalRunTimeDiv100 has already been divided by 100. */
ulStatsAsPercentage =
fuckit->ulRunTimeCounter / ulTotalRunTime;
if( ulStatsAsPercentage > 0UL )
sprintf( pcWriteBuffer, "%30s %10lu %10lu%% %5d %5d\n",
fuckit->pcTaskName,
fuckit->ulRunTimeCounter,
ulStatsAsPercentage,
*((int *)(&fuckit->usStackHighWaterMark)+1),
fuckit->uxBasePriority);
else
/* If the percentage is zero here then the task has
consumed less than 1% of the total run time. */
sprintf( pcWriteBuffer, "%30s %10lu %10s %5d %5d\n",
fuckit->pcTaskName,
"<1%",
*((uint32_t *)(&fuckit->usStackHighWaterMark)+1),
pcWriteBuffer += strlen( ( char * ) pcWriteBuffer );
// Serial.printf("len: %d, idx: %d\n", pcWriteBuffer - str, x);
Serial.print(str);
/* The array is no longer needed, free the memory it consumes. */
// vPortFree( pxTaskStatusArray );
// free(str);
