ESP32-C3 platformio arduino framework run-time error with 2MB flash
Posted: Tue Oct 03, 2023 5:50 am
I have an ESP32-C3 AI thinker module with 2MB flash. I have used this before with platformio and arduino framework (worked fine about a year ago).
But now I get the following run time error complaining about the detected flash size 2MB being smaller than the binary image (4MB).
This is the successful build log
partitions.csv
platformio.ini
Has something changed in the last year ? Is there some way to specify the flash size in the platformio.ini file ? I can't find any other platformio supported ESP32-C3 board or module so I assumed just the partitions.csv file would be sufficient to specify a 2MB binary image.
BTW, I can flash and run example sketches without a problem using the Arduino IDE 1.8.19 after selecting the 2MB flash menu option for ESP32-C3.
ELF file SHA256: bfb337d64580b7e5
E (526) esp_core_dump_flash: Core dump flash config is corrupted! CRC=0x7bd5c66f instead of 0x0
Rebooting...
ESP-ROM:esp32c3-api1-20210207
Build:Feb 7 2021
rst:0x3 (RTC_SW_SYS_RST),boot:0xc (SPI_FAST_FLASH_BOOT)
Saved PC:0x403819b6
SPIWP:0xee
mode:DIO, clock div:2
load:0x3fcd5810,len:0x438
load:0x403cc710,len:0x918
load:0x403ce710,len:0x24e4
entry 0x403cc710
E (167) spi_flash: Detected size(2048k) smaller than the size in the binary image header(4096k). Probe failed.
assert failed: do_core_init startup.c:326 (flash_ret == ESP_OK)
Core 0 register dump:
MEPC : 0x40381df6 RA : 0x403871c0 SP : 0x3fcde190 GP : 0x3fc8e800
TP : 0x00000000 T0 : 0x37363534 T1 : 0x7271706f T2 : 0x33323130
S0/FP : 0x3fcde2ff S1 : 0x00000088 A0 : 0x3fcde1f4 A1 : 0x3fc90d0d
A2 : 0x00000001 A3 : 0x00000029 A4 : 0x00000001 A5 : 0x3fc97000
A6 : 0x7a797877 A7 : 0x76757473 S2 : 0x3fcde1e8 S3 : 0x00000001
S4 : 0x3fcde1e8 S5 : 0x4201129c S6 : 0x42000020 S7 : 0x3c090020
S8 : 0x00010020 S9 : 0x00000000 S10 : 0x00000000 S11 : 0x00000000
T3 : 0x6e6d6c6b T4 : 0x6a696867 T5 : 0x66656463 T6 : 0x62613938
MSTATUS : 0x00001801 MTVEC : 0x40380001 MCAUSE : 0x00000007 MTVAL : 0x00000000
MHARTID : 0x00000000
Linking .pio/build/esp32c3/firmware.elf
Retrieving maximum program size .pio/build/esp32c3/firmware.elf
Checking size .pio/build/esp32c3/firmware.elf
Advanced Memory Usage is available via "PlatformIO Home > Project Inspect"
RAM: [= ] 10.2% (used 33556 bytes from 327680 bytes)
Flash: [==== ] 35.6% (used 699800 bytes from 1966080 bytes)
Building .pio/build/esp32c3/firmware.bin
esptool.py v3.3
Creating esp32c3 image...
Merged 2 ELF sections
Successfully created esp32c3 image.
# Name, Type, SubType, Offset, Size, Flags
# NVS : 24,576 bytes
# Factory app partition : 1,966,080 bytes
# LittleFS partition : 65,536 bytes
nvs, data, nvs, 0x00009000, 0x00006000,
phy_init, data, phy, 0x0000F000, 0x00001000,
factory, app, factory, 0x00010000, 0x001E0000,
spiffs, data, spiffs, 0x001F0000, 0x00010000,
[env:esp32-c3-devkitm-1]
platform = https://github.com/platformio/platform-espressif32.git
platform_packages =
platformio/framework-arduinoespressif32 @ https://github.com/espressif/arduino-esp32.git
framework = arduino
board = esp32-c3-devkitm-1
board_build.flash_mode = qio
board_build.partitions = partitions.csv
board_build.filesystem = littlefs
board_build.f_cpu = 80000000L
board_build.f_flash = 40000000L
