I'm new to the ESP32, I was used to work with AVR or ST mcu, and I get quite disorientated by the esp32 Technical Reference Manual.
I would like to use one of the four general-purpose to precise count time between two events. I want to directly write TIMGn_T0CONFIG_REG (n = 0) register to configure the timer and read TIMGn_T0LO_REG and TIMGn_T0HI_REG (n = 0) registers when a pin interrupt occurs. I wrote this example code but it doesn't compile and I couldn't find any reference that explain how to properly use REG_WRITE and REG_READ macros.
I hope that someone could help me to figure out what is wrong with this code
#define TIMG0_T0CONFIG_REG 0x3FF5F000
#define TIMG0_T0LO_REG
#define TIMG0_T0HI_REG
#define TIMG0_T0_DIVIDER 13
#define TIMG0_T0_INCREASE 30
#define TIMG0_T0_EN 31
#define T0_clk 0
uint32_t time_H = 0;
uint32_t time_L = 0;
// Timer setup: counting up, no prescaler (80MHz) and start.
REG_WRITE(TIMG0_T0CONFIG_REG, (T0_clk << TIMG0_T0_DIVIDER) | (1 << TIMG0_T0_INCREASE) | (1 << TIMG0_T0_EN));
time_L = REG_READ(TIMG0_T0LO_REG);
time_H = REG_READ(TIMG0_T0HI_REG);
Serial.println((uint64_t(start_time_H << 32) + start_time_L));
delay(1000);
